i havent posted in a while, and i have a problem
Old Jul 21, 2008 | 10:07 PM
sideshow elvis's Avatar
sideshow elvis
Junior Member
Default i havent posted in a while, and i have a problem
i have a loud knock, almost a loud tick, once it heats up its there, i just changed my oil,but was making the sound before also, its been going on for about two weeks now and i thought the oil change might do it.
but no luck.
it goes away after you go over idle, do i have a bad lifter, or is somthing loose? it was makin noise today when i got home from work, and it kept knockin all the way until the car died(i turned off the key).
ALSO I HIT A BIRD THE OTHER DAY and knocked out my left head light, does any body have one they want to sell?
thanks for the input,
chris
Old Jul 21, 2008 | 10:34 PM
Exubus's Avatar
Exubus
Default RE: i havent posted in a while, and i have a problem
I would guess chances are that you have the same "tick" that plagues a lot of 2.0s... believe it or not, it is very common and somewhat "normal" depending who you ask. The reality is, it is a slight slop in tolerance between the rocker arms and the pillow-blocks, and a moderate oiling issuethat eventually lead to this. A lot of Neon owners have had the same "tick." There are ways to get rid of this if you are willing to make the time and investment, or you can just live with the tick... in most cases, it isnt a direct detriment to performance.
My only concern is that you mentioned that it gets louder after the car heats up. Some people say that the "tick" is the loudest at a cold start, then subsides as the engine heats up. Other than that, your symptoms of the "tick" seem to be on-par with everyone else that has a ticking 2.0... especially the whole only-ticking-at-idle-but-goes-away-above-that statement.
Old Jul 21, 2008 | 11:00 PM
sideshow elvis
Junior Member
thanks
Old Jul 22, 2008 | 01:26 AM
Caraudioholic24's Avatar
Caraudioholic24
I have both for you but I founds out that the drivers side is an aftermarket one and the passenger is original. Pm me with an offer i also live in Rhode Island 02864
Old Jul 22, 2008 | 01:45 AM
N30N's Avatar
N30N
also if you get your pistons realigned(or whatever)it will cure the knocking...did anyone say that??but its no worry.if the tick speeds up as you give it gas then you need oil and if not your fine dude.have fun
Old Jul 22, 2008 | 01:56 AM
Exubus's Avatar
Exubus
ORIGINAL: N30N
Dude, we need to talk.
Old Jul 22, 2008 | 02:20 AM
Caraudioholic24
Lol
Old Jul 22, 2008 | 02:39 AM
N30N's Avatar
N30N
thats what i was told...is that right or whats the tech term for it
Old Jul 22, 2008 | 02:56 AM
j_son600's Avatar
j_son600
"pistons realigned" Only thing I can think of that might match that term would be honing and re ringing, or new rod bearings.
Old Jul 22, 2008 | 03:14 AM
N30N's Avatar
N30N
some dude at pep boys(and im not lying) told me this.cause there was a little civic doing that.i thought it needed oil also but it didnt.
