Coolant/Temperature problems in my neon. Need Help!!
Old Aug 24, 2008 | 11:55 PM
  #21
Exubus's Avatar
Exubus
You might as well flush everything out, yes. Both the flush and thermostat replacement is easy, but I am not sure what a shop would charge... I have always done those things in my driveway. I would guess it would be less than $100 for a shop to do both of those things for you.
Old Aug 25, 2008 | 12:21 AM
  #22
N30N's Avatar
N30N
Originally Posted by KARR
I have the whole online manual for this **** I mean car. Let me know if you need more help.
yea because you drive it like you stole it.LOL
Old Aug 25, 2008 | 12:24 AM
  #23
N30N's Avatar
N30N
Originally Posted by lilnicko11
well my car started getting hot again. I think its time to just buy a new thermostat and hope for the best. My car is around 110,000 miles now so it wouldn't hurt anyways. should i get my coolant flushed out as well to make sure there is no air in the lines and that the mixtures are right and all that jazz? how much would getting that done and the thermostat replaced run me u think??
bro cool your car off and empty your radiador then just open the cap and take a hose and let water run through it...just make sure your car is cool.then empty your resivar(or whatever) and refill...thats my way of a flush
Old Aug 25, 2008 | 08:21 AM
  #24
lilnicko11's Avatar
lilnicko11
thanks
Old Aug 25, 2008 | 10:28 AM
  #25
Exubus's Avatar
Exubus
After draining, I would recommend filling it up completely with just water, or better yet water with a bottle of flush treatment. Run the car for a bit until it come sup to temperature, adding water as needed to push the air out of the system. That way, you are gaurenteed that the water/flush treatment gets up to all the little crevices in the top and the bottom of the motor to make sure that no old coolant or deposits have been left behind.
In other words, just pushing water in to the top of the fill cap and letting it drain out the bottom may not completely get everything out. I prefer both a closed and open loop recirc while the car is running to gaurentee that I got everything. Then drain again, re-do and add your new coolant mixture.
Old Aug 31, 2008 | 10:17 PM
  #26
lilnicko11's Avatar
lilnicko11
Ok so today after a lil driving i decided to just pop the hood and check out my coolant reservoir to make sure my level was still ok. After peeping around a lil bit. I noticed wetness in front of my engine under the manifold if you will. Looks like it may be leaking where the coolant hose fittings are or maybe there are small cracks in the line that i can't see as well. As long as im not leaking near an expensive gasket I hope i can find it. So I will prolly just switch out my thermostat and replace the hose and the fittings. any ideas on how much this will take outta my pocket??
Old Aug 31, 2008 | 10:50 PM
  #27
Exubus's Avatar
Exubus
If you do it all yourself, I would say 50 bucks or less.
