2001 Neon replacement Stock Pistons. Where to buy?
Hello members,
I need help locating stock pistons for a 2001 Dodge Neon SOHC 2.0L.
I don't know the Engine type (Code name). I don't know where it's located.
My main concern is replacing the pistons with new stock ones so I can get the car back on the road. I have searched on ebay and Google but could not find pistons for 2001 Neon, which makes no sense. There are plenty of parts for a 99 or older so I don't know if pistons from 99 Neon will fit 2001 neon???
So someone please guide me as it's my first Dodge vehicle and I am not familiar with the engine types (codes like 420A) so I don't know what the 2.0L SOHC is called which is in my 2001 Neon?
Where can I buy new Stock Pistons?
Summit, Jegs, PAW, etc....
Plenty of suppliers out there.
Wiseco is one manufacturer
Dodge Neon 2.0L SOHC/DOHC
Series # Bore
MM/Inch Over
sizes Stroke Rod C.H. Head cc's Dome/Dish
Volume Comp Ratio Pin
Dia. Notes Buy Now
Inches K580M875
$439 87.50/3.445 Std 3.268 5.472 1.236 52 -5 8.8:1 .827 1
Metric K580M88
$439 88.00/3.464 .020 83 139 31.4 52 -5 8.8:1 21mm 1
K580M885
$439 88.50/3.484 .040 same as above 1
Inches K581M875
$439 87.50/3.445 Std 3.268 5.472 1.236 52 5 10.5:1 .827 -
Metric K581M88
$439 88.00/3.464 .020 83 139 31.4 52 5 10.5:1 21mm -
K581M885
$439 88.50/3.484 .040 same as above -
Notes:
#1 Most Wiseco pistons have offset pins. Pins must be offset the same as o.e. for quietest operation - Pin offset will be opposite of direction of engine rotation.
Notes: that apply to all Part #'s:
* Some pistons are listed with a range of compression ratio's. The low number is determined w/an un-cut deck and the high number is determined w/.030 piston to cylinder head clearance.
* Always check pistons to valve clearance - If using VTEC or like mechanisms- check w/longer duration higher lift lobe.
* Always run at least .030 piston to head clearance including gasket thickness.
* If piston appears to be different than expected, please do not hesitate to call Wiseco at 800-321-1364 to verify proper installation specifications.
Sales/Tech Line: (603) 378-0090
Email: info@ImportPerformanceParts.net
Thank You for visiting IPP - ImportPerformanceParts.net
*All prices on this site are subject to change without notice. Import Performance Parts™ disclaims responsibility for any printing or typographical errors, and does not guarantee that all information is accurate.Copyright © 2001-2008 (Import Performance Parts) All rights Reserved.
home | FAQ | contact us | can't find a part? | hot products | links | site map
Series # Bore
MM/Inch Over
Dia. Notes Buy Now
Inches K580M875
Metric K580M88
K580M885
Inches K581M875
Metric K581M88
K581M885
Notes:
After days of searching and calling I got a hold of someone at Advance Auto Parts and they happen to have the stock pistons for 2001 Neon for $31.48.
So all four for only $133.48.
Jegs, eBay, AutoZone, and many other stores I tried none of them carry pistons for a 2001 Neon SOHC.
Hmm thats what I was thinking too... why not some higher compression bling-bling... one of the biggest drawbacks of our engines.
Trending Topics
One of mine - see to have better quality - they carry Moog, Borg Warner, etc...
