the neon is back, for real...lol
Old Sep 6, 2008 | 12:20 AM
MoparMan00's Avatar
MoparMan00
Default the neon is back, for real...lol
so for detailed info on why it wasn't running, see http://forum.2GN.org/viewtopic.php?t=35174
otherwise here's the deal
rebuilt the front end,
electrical power issue,
replaced fusable link in alternator circuit,
engine power loss,
replaced TB,
checked all air intake and manifold connections/fuses/cables/hoses, etc...
replaced fuel filter/pump unit,
removed muffler(didnt solve the issue)
removed catback piping(still didnt solve the isse)
removed cat, issue solved,
(*cleaned*) and replaced cat,
replaced piping,
replaced muffler,
CAR RUNS!
i now obviously have a CEL, from the cat being decatified,
i am assuming that this wont go away, even if i disconnect the battery, so, how can i clear this particular code or something? its code P0420
and i know someone with a scantool....
Old Sep 7, 2008 | 10:45 AM
bone33's Avatar
bone33
the downstream O2 sensor is telling the cpu that something is wrong.
Old Sep 7, 2008 | 01:00 PM
mannyfresh18's Avatar
mannyfresh18
lol i dont have the cat on mine either and the engine code wont go away.
but what kind of scan tool can u use to put the code in ?
Old Sep 7, 2008 | 04:01 PM
Andpto's Avatar
Andpto
if you clear it will still comeback since the upstream sensor is reading different from the downstream sensor behind the cat.
You will need to do the spark plug non-fouler trick
https://dodgeforum.com/forum/showthr...t=96604#728767
Old Sep 7, 2008 | 11:20 PM
MoparMan00's Avatar
MoparMan00
the link you poseted andpto didnt seem to have pics....
heres one with pics though...http://www.msprotege.com/forum/showt...p?&t=123634664
i knew the reason i was getting a code, just not the remedy, thanks though
Old Sep 8, 2008 | 02:00 AM
Izero's Avatar
Izero
you need a new cat... there really isn't any way to "clean" a cat.... so spend the money and fix it right.... you may need a new 02 sensor specially if you let the current one sit in the open air while you took the cat off and ran the car... so yea... new high flow cat and new 02 sensor and you should be ok...
