Strange noise in the cab....
Old Sep 8, 2008 | 10:49 PM
rajdt's Avatar
rajdt
Default Strange noise in the cab....
I have 2003 Neon with 86000 miles on it. Last a couple of weeks there is some strange noise in the cab. It sounds like muffler hitting the body of the car but it is not that (checked it). From outside listened, car runs perfectly, no strange noise. Anyway, I looked around the engine and found that torque mounts (i think that may be the proper name for it) were worn. I bought them new (top and bottom) and changed but now the noise is even worse. I think the reason for that noise and vibrations (related to the speed of the engine-no matter what, driving or sitting in park), could be motor mount on the passenger side. What do you think? Am I at the right path?? If I am, how hard it is to replace that motor mount? I tried to take it off but space was too tight I couldn't get the motor mount out so I put it back again...
Old Sep 8, 2008 | 11:33 PM
smallblockfreak's Avatar
smallblockfreak
Did you check the heat shield if it has one?
Old Sep 8, 2008 | 11:52 PM
Adionik's Avatar
Adionik
Do you have any way to take pictures of your motor mounts? If you bought brand new ones and it worsened it....doesn't make much sense
Old Sep 8, 2008 | 11:56 PM
N30N's Avatar
N30N
welcome to the forum
Old Sep 9, 2008 | 12:06 AM
rajdt's Avatar
rajdt
Default strange noise...still...
I think pieces I replaced are (I believe) called TORQUE MOUNTS (not sure). Anyway here are pics. As I said there is a motor mount at the same side of the car (engine side) I think it went wrong. I just was not able to pull it out because the space was too tight. Any tricks??? Anybody??
Old Sep 9, 2008 | 12:44 AM
Adionik's Avatar
Adionik
Did you jack up the engine?
Old Sep 9, 2008 | 01:13 AM
rajdt's Avatar
rajdt
Default jacked up and lovered down....
Yes, I tried everything...lowered and jacked up...
Hope there is some Dodge mechanic here who can give me some good advice...
Old Sep 9, 2008 | 01:57 AM
N30N's Avatar
N30N
rajdt we dont have alot of 3rd shift people so if you check this tomarow you'll have more responces
Old Sep 9, 2008 | 10:48 AM
2000LX's Avatar
2000LX
when you replace the RH motor mounts - you have to place them in a specific distance - 119 MM is the measurement from the top rear bolt of the motor mount to the second hole on the strut tower.
Check the center mount as well - it is a PITA to replace - you have to jack the motor up - there is one center bolt - goes thru the RH lower frame rail - then there are four bolts that bolt it to the inside of the rail
Old Sep 9, 2008 | 12:03 PM
rajdt's Avatar
rajdt
Default I did that....
I did all that as you said but was not able to get that motor mount out! The motor mount sits IN the rail frame and there is not enough space to pull it out!
