Neon rear brakes
Old Sep 11, 2008 | 02:58 PM
Cincydad's Avatar
Cincydad
Default Neon rear brakes
We are trying to replace the rear brakes in a 2003 Neon...we cannot get the drums off. We took the adjuster all of the way in, used pry bars, and Stay loose and nothing has worked...does anyone have any suggestions?
Old Sep 11, 2008 | 05:36 PM
bone33's Avatar
bone33
release the ebrake!
beat the crap out of the drums with a big as$ hammer. it will break free and if it doesnt, then get a bigger hammer and bust up the drums.
Old Sep 11, 2008 | 08:50 PM
mjs182004's Avatar
mjs182004
+ 1 ^^
Old Sep 11, 2008 | 09:31 PM
pasgaines's Avatar
pasgaines
mine did the same thing and i beat the h3ll out them with a hammer,it worked after i worked up a big sweat.
Old Sep 12, 2008 | 02:05 AM
et_agus's Avatar
et_agus
I agree with the hammer! Not so sure about beating the crap out of it, but with some gentle persuasion they'll come off.
Old Sep 12, 2008 | 02:32 AM
contagious19's Avatar
contagious19
hammer da **** out of it
Old Sep 12, 2008 | 10:07 PM
pasgaines's Avatar
pasgaines
i really had to swing hard,i had a little 2x4 i put up against the edge of the drum and it tokk awile to come off i tried the tap tap approach till i got frustrated.lol
Old Sep 13, 2008 | 01:06 AM
Exubus's Avatar
Exubus
BFH and brass flat, FTW.
Old Sep 27, 2008 | 02:35 AM
zz_cro's Avatar
zz_cro
Elegant solution...if you have blow torch try heating the drum (especially the center area of it) and then giving it a firm blow with the hammer). Heating the drum will cause the drum to expand a bit and break loose from the hub).
Old Sep 27, 2008 | 04:42 AM
darthroush's Avatar
darthroush
Section Moderator
Use a dead blow hammer and swing!
