2001 2.0 Neon SOHC timing belt tensioner
Old Oct 1, 2008 | 07:48 AM
briandownunda's Avatar
briandownunda
Default 2001 2.0 Neon SOHC timing belt tensioner
Hi,
I have a broken timing belt on my "2001" 2.0 SOHC Plymouth Neon. Looking at the manual for the 2000 Neon, the timing belt tensioner appears very different than the one on my 2001.
Mine has something akin to a vertical mounted shock that has 2 bolts allowing it to be raised up or down to put pressure on the tensioner pulley.
I have a couple of questions:
1) Do I really need to replace this when changing the timing belt ? If so, which tensioner should I replace it with ?
2) If I don't need to replace it, how do I tighten/adjust it ?
BTW, I don't mind getting a pointer to a thread that answers my questions.
Thanks in advance,
Brian
Old Oct 1, 2008 | 09:05 AM
chenzo's Avatar
chenzo
I dont have a specific thread to point you to, but you would have much better luck posting this in the 2nd gen Neon forum.
Old Oct 1, 2008 | 12:44 PM
briandownunda
Hi,
THis is the 2nd Gen Neon Forum ;-)
Thanks,
Brian
Old Oct 1, 2008 | 06:04 PM
contagious19's Avatar
contagious19
take a pic for me and i could probably help
