My winter wheels are here!
#31
In case you guys didn't understand, I test fitted a lug on the wheel, I did not install them. Well anouther let down the place that I had these tires mounted(mavis tire) put the wheels on so tight that my compressor can't get them off at 130psi and I can't get them of because the whole motor moves when I use a breaker bar. So I am going yo have to take the car somewhere and have them change the tires and make sure they put them to 110psi or less...
#35
#36
#37
Well the only thing I got done their was getting the two keys off on the front wheels, which were the only things holding me back. BUT, now the weather is holding me back, freezing rain for the next two days, If it was just raining I'd go out their and do it but not in freezing rain.... Hopefully their will be a break in the weather tomorrow so I can get them on because snow is in the forecast for next week......
#38
Ok so I got out there today and just beat the freezing rain/ snow right now....
I also have 300+ lbs of weight in the trunk
I also saw where my tires were hitting. The right wheel was rubing aginst the metal on the inside of the wheel well when the wheel is turned to the left and the left wheel rubs the inner plastic fender well when I turn right. I guess I need to get an alignment when I put the summer's back on in march....
#39
I put brand new studded M+S tires on mine with the stock 14" steelies. I prolly won't need the studs down here in ohio but deff help when i'm driving back to ny and going right past lake erie. I have still yet to see the purple people eater while i'm driving past cleveland . I think your car should look pretty good with those rims for the winter. Better than my steelies.
