interior question
Old Feb 13, 2005 | 10:55 PM
jonbonazza's Avatar
jonbonazza
Default interior question
a quick question:
i want to paint my vents and some other stuff... what kind/brand of paint should i use? thnx in advance
Old Feb 14, 2005 | 12:09 AM
LowSlowNeon's Avatar
LowSlowNeon
Default RE: interior question
I used some high heat auto paint for mine. I put about 3 or 4 very light coats on it, then put about 2 coats of clear on it. It worked pretty well.
There is a picture of my vents. It was the only one I could find really....I had my dash all torn up when I was puttin in some guages. But you can see my vents nonetheless.
Old Feb 14, 2005 | 01:24 AM
jonbonazza's Avatar
jonbonazza
thnx man ill try that... any brands you recommend?
Old Feb 14, 2005 | 04:58 AM
Drew00's Avatar
Drew00
i like the yellow and black.... two of my favorite colors. you did a nice job.
Drew
Old Feb 14, 2005 | 05:32 AM
LowSlowNeon
Thanks, I wish I could photoshop what I want my car to look like when I'm done. I'm planning on getting yellow racing seats with black harnesses, black/anthracite/gunmetal wheels with yellow painted calipers, tint my windows to give it a more dark look, accent some more interior pieces. I just wish I could photoshop what I want it to be, cause I think it would be awesome....even for someone who doesn't like yellow with black.
Old Feb 14, 2005 | 07:02 PM
Dj_plutonium's Avatar
Dj_plutonium
Hey NEONSXT04 vry nice im tryin to do the exact same thing except my neon is yello! how did u get ur dash off like that?
Old Feb 14, 2005 | 08:50 PM
phaythe's Avatar
phaythe
Here are some pics of some of the interior work I've done in my Neon and my Cherokee...
I used Krylon Fusion, it's worked out great...just be sure you don't get overzealous and lay on the paint too thick...THIN layers multiple times...don't gob it on there :P
[IMG]local://upfiles/11812/7D85BA187EB3415BB90BE66DF9CB1615.jpg[/IMG]
[IMG]local://upfiles/11812/38D6FBDCF82E4DA7B232F242D009F58A.jpg[/IMG]
Old Feb 14, 2005 | 11:13 PM
LowSlowNeon
ORIGINAL: Dj_plutonium
I already told you in another post. There is a screw on each side of the dash, if you open the car door you will see it, then there is two screws in the defrost vent, and also two behind the vents in the center of the car. You will have to take the drivers and passenger side A-Pillars off as well, but after that it just pops up.
Old Mar 13, 2005 | 11:13 PM
NeonOn19s's Avatar
NeonOn19s
I actually took apart my whole interior and preped it and took it to a body shop and had them spray with Dupont Silver and had it cleared. They also put a flex agent in it so it wouldn't crack or peel in removal. It has the same durability as the car's exterior. It looks real good
Old Mar 14, 2005 | 02:23 AM
casper's Avatar
casper
How much did that cost you?
