spark plugs.
well bud if you ever want any opinions on anything just throw it on here cause im on in the morning and well give you good ideas
the only thing that i know for the time being is that im going for the msd coil pack and the granatelli plug wires from modern performance. i figure later on down the road ill get the new exaust system as well. i am still interested in the intake manifold and throttle body, so if yall have some good choices let me know.
anything from modern performance is good and msd wires and coil pack is really good also.
i have a strait pipe with no little holes in it and a 2.5" cut out and my car sounds like an srt with no turbo LOL.but like exhaust wise i would consider Borla
gotcha. yea im going to order the msd coil pack and those wires later today, i just need to find out if my stock coil pack has round or flat terminals. the header and exaust im looking at is by pacesetter and im wondering if its a direct fit. it says it is but alot of the times you have to make adjustments to get the pipes to fit. which is no biggie. i guess i could contact them just to be sure.
modern performance said the header i want is a direct fit and will bolt up to everything that the original did, even the o2 sensor housing is the same. on the exaust, i may have to trim an inch or 2 off the tail pipe and make some notches in the bumper since this is going to be a dual exaust. which is not a biggie for me. as for the coil pack, the terminals for the connector are flat. any advice on the intake manifold and throttle body. i see both on mp's site that look nice.
