Why is my HEAT only lukewarm?
Old Dec 29, 2008 | 11:05 PM
Michelangelo's Avatar
Michelangelo
Default Why is my HEAT only lukewarm?
2000 4cylinder, 5 spd wtih 116k miles.
The heater only blows out semi warm air, it won't give me any hot air. This really sucks when it's so cold this winter. I replaced the rad. thermostat thinking that might have been the problem but no dice!
Any ideas on what to do?
Old Dec 29, 2008 | 11:09 PM
blkdodge360's Avatar
blkdodge360
do u smell anti freeze in the car?
Old Dec 29, 2008 | 11:18 PM
mcfisher1980's Avatar
mcfisher1980
check your heater core as well
Old Dec 29, 2008 | 11:25 PM
Michelangelo
No, no signs or odd smells at all. Doesn't leak any fluids either. The AC works perfect. Matter of fact when i turn it to front window defrost the recirc **** automatically moves to fresh air and the air hitting the window seems to be colder, almost like the AC gets turned on!
Old Dec 29, 2008 | 11:28 PM
blkdodge360
yea i was going to say the heater core
Old Dec 29, 2008 | 11:32 PM
Michelangelo
So you think it's the heater core or does my info discount that?
Why does a heater core go bad, where's it located and is it costly and difficult to replace? I do most of my own wrenching and maintenance as long as it's not too bad.
Old Dec 29, 2008 | 11:41 PM
blkdodge360
my trucks heater core has got a leak sometimes theyll clog up. im not sure were it would be mostly behind the dash. price im not sure
Old Dec 29, 2008 | 11:46 PM
blkdodge360
whats the temp on the thermostat, and u replaced the radiator?
Old Dec 30, 2008 | 01:07 AM
Michelangelo
No didn't replace radiator, just the thermostat. The temp reads about 1/4 of the way up the temp guage, seems normal to me.
Old Dec 30, 2008 | 01:11 AM
blkdodge360
sometimes youll get air pockets in the coolant and can cause no heat
