Headers with CARB label?
Old Jan 1, 2009 | 11:56 PM
gcrn7081's Avatar
gcrn7081
Default Headers with CARB label?
Any headers out there with a CARB label?
Old Jan 2, 2009 | 12:02 AM
mcfisher1980's Avatar
mcfisher1980
i have seen some. all that label is for is to let you know that it passed the cailfornia air resourse board of approval.
Old Jan 2, 2009 | 12:04 AM
gcrn7081's Avatar
gcrn7081
Right. Without it, I can't pass smog here in Calif. Correct?
Can you post some names or web links?
Old Jan 2, 2009 | 12:14 AM
mcfisher1980
if its an aftermarket part that deals with your emissions and it doesent have that label on it, i do not believe it will pass. i could be wrong on that, so dont quote me on it. all i know is that california has gotten very strict on their emissions testing. i know alot of other states are starting to do their own thing just as california has about smog and stuff like that.
Old Jan 2, 2009 | 12:18 AM
gcrn7081's Avatar
gcrn7081
Pacesetters looks like it has carb I will check
Old Jan 2, 2009 | 12:28 AM
mcfisher1980
sorry i didnt post any links. i didnt catch that until i cam back through. what site did you find the pacesetters at. i know here va they have gotten strict about aftermarket parts. some inspection stations are implementing the decibel meter testing of the exhaust system now
Old Jan 2, 2009 | 12:39 AM
gcrn7081's Avatar
gcrn7081
I will call them tomorrow. I found online many cars that are for their product, just not the neon.
I also found in my search that the K&N intake is carb exempt.
http://www.knfilters.com/search/prod...Prod=69-2520TR
-and-
http://www.knfilters.com/search/appl...Prod=69-2520TR
Old Jan 2, 2009 | 01:34 PM
contagious19's Avatar
contagious19
i have a pacesetter and its c.a.r.b. approved, im in cali also. oh if u get a neon r/t header. its the same as the borla header which would give u better gains, i had a borla header but i had to part with it since i needed money
Old Jan 2, 2009 | 01:41 PM
gcrn7081's Avatar
gcrn7081
Good advice! So, the neon rt header will fit my neon? And it's carb approved? Any "special" hook ups? I will weight out the price between the two then!
Thanks!
Old Jan 3, 2009 | 04:52 AM
contagious19
actually it doesnt have a c.a.r.b number since its a stock header, u should pass smog fine wit no problems i bougth my r/t header for 85 bucks. and no special hookups its a direct bolt on, pacestter is not direct bolt on. if i were u, i would get da r/t header best short tube header for the neon
