2000 dodge neon question
Old Jan 6, 2009 | 12:39 AM
jbn7474's Avatar
jbn7474
Default 2000 dodge neon question
Hi all,
I have a 2000 dodge neon. There is clunking coming from the front end when I go over a series of bumps. I can feel it in the floor. I had the struts and mounts replaced last summer both front and rear. I also had the tie rod ends replaced too. I had my friend look over the front suspension, the sway bar and end links, ball joints, cv, he said they were all fine. When I took it to get a new exhaust on my car at meinekee they said my lower control arms were in rough shape. I didnt have them do any work cause I wanted to get a 2nd opinion before I shell out money. I would have my friend do it, but its winter and he usually works outside and cant get into a garage for him to fix it. So I was wondering how much it might cost me at a garage. I am gonna call around for the best deal. Do you think its the control arms? My friend thinks it might just be the bushings that just need replacing. I also have to get a camber set when I get an alignment, cause for whatever reason you cant adjust the front camber on the passanger side. I would appreciate any input on this matter, thanks for any replies
Old Jan 6, 2009 | 01:10 AM
darthroush's Avatar
darthroush
Section Moderator
I have a brand new pair of control arm bushings waiting for either me or a shop to put them in. They will make all sorts of weird noise if they are bad.
Old Jan 7, 2009 | 05:13 PM
jbn7474's Avatar
jbn7474
Got my control arm bushings and sway bar end links and alignment done today and it seems to have solved the problem. Took it for a spin after it seemed alot smoother and no clunking, steering is tighter too. So I hope that will be all for issues for a while. Thanks for the reply.
Old Jan 7, 2009 | 08:55 PM
darthroush's Avatar
darthroush
Section Moderator
NP, may try and get mine done if it ends up going to the shop for the tranny.
