Trouble Starting
Old Jan 18, 2009 | 04:33 PM
Izero's Avatar
Izero
Default Trouble Starting
Ok so if I dont start my car for a day or two and i go to start it it has trouble starting... Like sometimes the starter wont engage and it almost sounds like there isn't enough power in the battery to crank it... but when i check my voltmeter to the battery i have a perfect 12-12.5 volts in there... I am pondering if it is the ignition coil that could be the problem or if it could be the starter.... Such a pain in the @$$....
Old Jan 18, 2009 | 04:43 PM
LowSlowNeon's Avatar
LowSlowNeon
What kind of noise does it make when it won't start? If your battery is good, I would be leaning towards the starter. Mine took a dump after only like 30k miles. My original battery is still going strong 5 years later. It even started when it was below 0 last week.
Old Jan 18, 2009 | 05:05 PM
Izero's Avatar
Izero
I'll get a video of it tonight... you know what I'll do it right now... give me like 20 min or so...
Old Jan 18, 2009 | 05:15 PM
Izero's Avatar
Izero
ok heres a link to the video...
http://s11.photobucket.com/albums/a1...leStarting.flv
Old Jan 18, 2009 | 05:56 PM
mcfisher1980's Avatar
mcfisher1980
you may want to pull your starter out and have it checked. that didnt sound right when it started
Old Jan 18, 2009 | 07:38 PM
LowSlowNeon
Well that didn't sound exactly like mine when it went bad. Mine would sometimes not start the first time you turned the key. Sometimes I could hear a "grinding" noise and it would not start. Every time it did not start if I turned the key to off then tried to start it again it would. Still think its your starter.
Old Jan 18, 2009 | 09:40 PM
mjs182004's Avatar
mjs182004
humm, very strange. has it always started every time?
Old Jan 18, 2009 | 11:52 PM
Izero's Avatar
Izero
yup usually ALWAYS started in like 2-3 cranks when its cold and like 1 or 2 when its warm out.... idk.... I think ill just replace the starter and then prolly the ignition coil.... anyone have any suggestions on where to go for a new (NON-REMANUFACTURED) starter? for a reasonable price? AND btw she only started so quick b/c i started her like 20 min before....
Old Jan 18, 2009 | 11:55 PM
I own only Dodge's Avatar
I own only Dodge
Yea dude sounds like your starter to me. Brushes are probably worn down to where there not passin the current efficently through the bendix of the starter< causing it to drag, then spin up and start the engine
Old Jan 19, 2009 | 12:03 AM
Izero's Avatar
Izero
thats what i was thinking b/c I KNOW she's getting enough juice its just not passing through the starter.... so its gotta be.... which is gonna be a pain in the *** to change in this effin' cold
