What should I do?
What should I do?
Ok, I my front drivers side tire has slowly been leaking air. It takes about a week before I have to go put air in it again. So I took it to the tire shop today and had them take a look at it for leaks and about 10 minutes after they had it they bring the wheel in to me and tell me I need new wheels. They tell me that the chrome is corroding and that is causing it to slowly leak air and that if I don't replace the wheels it is going to eat my tires basically and I'll have to get new tires and wheels. The wheels in question are my 7 spoke chrome stock wheels. I didn't take a picture so I can't post it up as I had them mount the tire back on because I wasn't ready to purchase any wheels yet and I really don't. So my question is what do you think I should do. I could see that is beginning to corrode and that the chrome is beginning to come off. I also feel that they are trying to yank my chain and get me into shelling out 400 bucks for some new wheels. I am considering just leaving them on there until april/may when I can then put my summer wheels back on which would give me more time to either find wheels I like or find some stock neon wheels. Input? If I had to purchase some wheels right now, it would probably be some 15" Rota Slipstreams. But again, I really don't want to shell out 400-500 for winter wheels, plus I want to buy a clutch in the next month and have it installed.
Well a good shop would of tryed to take a wizer wheel and try to get the corrosion off of the wheel, and then remount the wheel.... this accually happens to allumium when it starts to pit, sometimes the bead will not seal tightly.... i would try this method before i worry about buy new wheels...
Trending Topics
Lowslow, I would say try another shop. See what they say. If it is the same thing or something with the wheel take it to a wheel repair shop. The place I have taken mine to has fixed a cracked and bent on both sides wheel and a wheel where about one inch in, it was bent real bad. They most likely can fix that too. So just find a wheel repair shop and your looking at about 100-150 I would say. Either that or go to a junkyard and get a wheel.
