do you have the manifold already because it might be cheaper and easier to port and polish your stock mainfold. i don't know if the srt-4 manifold will fit on your car.
heard that they cast the manifolds by pouring the metal in sand a die which leaves the manifold rough and bumpy on the inside, if the have a die grider yo could probably smooth it yourself just don't go crazy. i think the 1st gens were made of metal not sure about 2nd gens.
is it possible to run seperit throttle bodies? like have 4 of them? that would be insain.
Can you say loss of power. It would do nothing, the only way it would work would be if you used 4-15MM throtle bodys,or somethin, and then it would be no better than a single 55.
