Halo Lights with HID kit
Old Feb 20, 2009 | 11:32 AM
NeonOn19s's Avatar
NeonOn19s
i'm installing the projector lights on mine this weekend maybe. I'm still waiting on the H1 HID bulbs to show.
Old Feb 21, 2009 | 10:46 AM
Kath's Avatar
Kath
Originally Posted by irishking
mine plugs right into the socket. so when i flicked my highs on the switched from low than when u flick back to low the high go off. the dont both come on. Than what i did is wired the led lights in mine to the turn signals and than the halos i wired into my parking lights. maybe an hour hour and a half project easy to do..
I like it, i didn't think of that when i installed on my former R/T. next time I will definitely do it your way.
Old Feb 21, 2009 | 12:08 PM
NeonOn19s's Avatar
NeonOn19s
ok... i have the lights and the H1 bulbs ( HID) and they don't fit... I guess that I have to modify the housing to fit. any ideas???? ( SRTGTR34) I have it all, and the return line from the HID is holding up the install..
Old Feb 21, 2009 | 07:33 PM
srtgtr34's Avatar
srtgtr34
Check you pm's at the org.
And, what return line?
Old Feb 21, 2009 | 08:15 PM
NeonOn19s's Avatar
NeonOn19s
the return line is the white line comming from the top of the HID bulb
Old Feb 21, 2009 | 08:33 PM
srtgtr34's Avatar
srtgtr34
Does the "return line" look that far away from the bulb as it does in that pic because I am looking at my spare 4300's and it looks closer.
I got a reply from you on 2gn but it says nothing...
Old Mar 6, 2009 | 11:28 AM
blueproracer's Avatar
blueproracer
I have both. My hid is the hottest possible 32000 or something. They are purple. (cardomain.com - blueproracer) i have a pic. I did have to drill the hole a little. With hid they have there own grounding and don't need to ground to the assembley. I love it. Alot of people can't figure out what's coming at night.
Old Feb 21, 2013 | 10:56 AM
Damian Badman's Avatar
Damian Badman
Default Halos
I put halo's in my car about a month ago I wired the ring to turn on with a toggle switch beings they us no more then a ml amp I leave them on all the time idk if this will help anyone but its useful info I think I also wires the 3 corner lights on my Halo's to come on with my turn signals looks good and figured others may like
Old Feb 22, 2013 | 06:28 PM
caoe74's Avatar
caoe74
Has anyone installed the halo lights with the HID kit. I already have the halos installed and im really liking the HID kit. But I have mixed answers. People tell me the 6k kit will melt the housing of the lights. Also if i install the HID kit and it is possible to do with damaging the housing what do you do about the high beams. there are two sets of bulbs in the halo lights now. one for low and one for high beams. Any ideas or someone that has the answer please let me know. thanks.
The light output color is measured in Kelvin degrees which have nothing to do with temperature. The wattage is what you should be caring about. Halogens over 55 watts like those that will give you a bluish output will not only melt or fade your headlight housing but they will fry your cables and connector sockets.
If you go the HID route you should be looking into 6000 Kelvin or lower to keep your car on the "legal" side. Anything above 6000K will start looking too blue or even pinkish to the like of law enforcement. Plus the higher the number the less usable light. HIDs come mostly in 35 watts, though you can find 55 watt bulbs and ballasts. You will be more than safe running 35 watt HIDs with properly aligned projectors. No risk of melting or fading, and the car will have a more modern look.
