hey new to this!!
Old Feb 28, 2005 | 01:56 AM
2002NeonSE's Avatar
2002NeonSE
Default hey new to this!!
Hey new to the forums, having some trouble with my car, hesitation, and jerking when idling anyone out there have any idea what could be wrong, it has almost 60,000 miles!!!
Old Feb 28, 2005 | 02:08 AM
LowSlowNeon's Avatar
LowSlowNeon
Default RE: hey new to this!!
Could be spark plugs, wires, clogged air filter, etc. When does it do it? Anything else you can tell us about it? Welcome to the forums.
Old Feb 28, 2005 | 02:12 AM
RayDog26's Avatar
RayDog26
is your check engine light on ?? when i got my car it was miss firing and barely started and ran b ut i put new plugs and wires and it solved all of that.. the simple things some times make all the difference....give us some more details and we can prolly help
Old Feb 28, 2005 | 12:09 PM
2002NeonSE's Avatar
2002NeonSE
air filter and oil were changed about 3,000 miles ago, spark plugs and "throttle body cleaning" was done in July that is what dealer said was wrong. when at a light car will jerk until I start to move again poor acceleration, lots of hestitation, it only does this when i'm doing lower speeds, and yes this is a auto, when doing high speeds car is fine, and the check engine light was on in july when i took it, but now it is not on would really appreciate feedback
Thanks
Old Feb 28, 2005 | 05:00 PM
RayDog26's Avatar
RayDog26
ummm have some one help you check your motor mounts they could be broken that would cause the car to jump in gear....or it could very well be a miss fire problem but thats rare since you don't seem to have other problems.... so i would check ur motor mounts its easy to do
Old Feb 28, 2005 | 05:59 PM
LowSlowNeon
Not your mounts. How is your gas mileage? Its something either fuel, spark, or air related.
Old Mar 1, 2005 | 12:26 AM
2002NeonSE's Avatar
2002NeonSE
Thanks for the feedback, gas mileage is fine, I have heard alot of it could be fuel related so I will check into that
Thanks!!
Old Mar 1, 2005 | 01:48 AM
casper's Avatar
casper
Try some injector cleaner and dry gas. It could be clogged injectors or condensation in the gas.
