Please help!!!!! I have a 2001 Neon R/T and having a little bit of trouble here. While driving after car is warmed up, I'm having hesitating problems through HARD acceleration. normal driving it's alright and when the engine is cold no hesitation. I'm thinking that it is the clutch going out on me, but it only does it when it's warmed up. I was also thinking the type of fuel, brand that is, the car requiers a higher octane for gas, which I use. I anyone has suggested please let me know.
No the ses light isnt lit. For example, Fast acceleration, it'll be fine up to around 4,000 rpm then hesitate, like a small jerking then right at 6000 it's fine, when it hits 6000 it feels like it graps then.
when the problem came up i checked them they where bad, so replaced them, I replaced with platinum that doesn't require gapping, could that be it, cause the gap on normal plugs for the car is .40
AIR FILTER IS NEW, I'LL CHECK THE PLUGS ON IT, IF I TAKE IT IN FOR ENGINE DIAGNOSTICS WITH OUT CHECK ENGINE LIGHT ON WILL THEY BE ABLE TO TELL ME ANYTHING YOU THINK OR JUST A WASTE OF MY TIME?
