Mopar Timing Belt Tensioner 2.0
Old Mar 6, 2005 | 08:56 PM
lblackneon's Avatar
lblackneon
Default Mopar Timing Belt Tensioner 2.0
When I get paid, I am leaning towards doing a cam job to upgrade my car. I'm thinking about getting a cam 10 or 12, cam gear and valve springs. Since I am going to have to take the timing belt off to change my cam, I figured it wont hurt to change it while I'm there. I also saw a Mopar Timing Belt Tensioner 2.0 and I was wondering if it's worth getting for about 130 dollars. Of course I would rather get performance parts but I also want to help my car to last longer.
What do u all think of the tensioner? Is it worth buying? My car has about 68,000 miles on it.
Old Mar 6, 2005 | 11:43 PM
casper's Avatar
casper
Default RE: Mopar Timing Belt Tensioner 2.0
I would think that the tensioner is fine and you don't need a new one. I would get the crane #12 or #14, the 10 is just about a stock cam.
Old Mar 7, 2005 | 04:06 AM
lblackneon's Avatar
lblackneon
I thought the cam 10 was slightly better than the cam on the Neon RT's. Wouldn't the cam alone give me like 10-15 hp?
Old Mar 7, 2005 | 11:03 PM
casper's Avatar
casper
Yeah there is an increase your hp a little, but the #12 is the same price and gives you a better cam for future mods and gives you about the same increase with mild mods.
Old Mar 9, 2005 | 02:38 PM
lblackneon's Avatar
lblackneon
W/ the cam 10, how many miles can u go until u have to replace the timing belt?
The cam 12 is 60,000 miles.
Old Mar 10, 2005 | 02:56 AM
lblackneon's Avatar
lblackneon
Future mods like what? Turbo? If that's the case, I doubt I will spend the money and put a turbo in my car. I know the cam 12 spools the turbo faster.
If u consider what I have as mild mods and the last thing I would do to upgrade my engine is to change the computer (as of now), would a cam 10 be fine? Will it give about the same hp increase at the same rpm levels in comparison? I know the higher the rpm the more hp (that's probably why the cam 12 is favored and will win in the hp gain).
Old Mar 11, 2005 | 11:50 AM
Neon Lights's Avatar
Neon Lights
in my experence you would be better off getting a new tensioner. i did a head job on a gen 1 and didnt change it, the car came back with a broken tensioner thus back to square 1. new head etc. the dealer recomends a new tensioner with the belt repalcment. it is around 160.00cdn, concerding the cost of an engine job its worth it.
Old Mar 11, 2005 | 04:11 PM
casper's Avatar
casper
I would still say go with the #12, you don't have to go turbo to take advantage of it. If I remember correctly the 12 pushs the power curve a little higher in the rpm range than the 10, but if you are gonna spend like $500 on a cam why put one that is just a slight bit more aggresive on, when you can put on the 12 and get more. I am not sure of what mods you have now, but with intake, full exhaust, PCM, TB, and maybe some port and polish the 12 will be a lot better.
Old Mar 12, 2005 | 08:37 AM
lblackneon's Avatar
lblackneon
I'm not a mechanic by any means so, changing the timing belt can be costly w/ anyone (other than me) doing the job. That's why I'm thinking about the cam 10 because it lasts longer. If I was good at working on cars I wouldn't think at all and just get the cam 12. I'm still debating which one though.
FYI, the mods I have on my car have been on my signature.
Old Mar 12, 2005 | 02:10 PM
casper's Avatar
casper
Yeah I swear I saw them in your sig. Stupid me, lol. The timing belt is not that bad of a job.
