fog lights
Hey guys,
I have a dodge neon 2004 Sx 2.0 so it has two foglights in the front..
But somehow I cant get it to Work..!!?:O
Well I try to turn it ON...and to see i the LIGHT of the foglight in use in my dashboard...and I only get the Headlights...!
If someone could help me how to turn it on!!
Thank you! very appreciated!
( sorry for my english!)
LOL!? Look at the bulb and if the filament wire is broken, the bulb is blown. Pull the fuse out. If the metal wire/band inside is broken, the fuse is blown, or use a fuse tester to check.
Nothing against you personally, but if you can't tell if a bulb is blown, maybe you should take it somewhere or get a friend who knows a bit more about cars to help you. Electrical stuff can be a PITA, especially if you are not experienced with it.
okay I changed the fuse that's in the fusebox in behind the dashboard...
I tried to check the fuse box under the hood, but I don`t find the fog lights in the cover..
The bulbs are fine..
What to do!:O
What to do!:O
Trending Topics
Don't forget the blinker fluid. In all seriousness though, I'd check bulbs, fuses by the drivers side door, fuses/relays in the engine bay, multifunction switch (although i don't know how to check that). Did your fogs ever work or did you buy the car with the fogs not working?
