pt gt engine
Old Apr 23, 2009 | 03:55 AM
audiobahn4ever's Avatar
audiobahn4ever
Default pt gt engine
I have a 2000 neon, will the 2.4 turbo motor fit in my car?
Old Apr 23, 2009 | 04:40 AM
fLaMeRED01's Avatar
fLaMeRED01
yes, for the most part... The PT-GT engine uses different IC piping and a different intake manifold. Other than that it is the same as the SRT. It will fit in just fine, but do to the 03+ NGC controller you will need the full wiring harnesses (engine and dash) along with the cluster.
Old Apr 23, 2009 | 07:06 AM
jagass's Avatar
jagass
I believe it's a yes...lol
Old Apr 23, 2009 | 06:59 PM
darthroush's Avatar
darthroush
Section Moderator
Isn't the trick with the PT GT engine is that you can use an auto instead of a manual with it?
Old Apr 23, 2009 | 07:55 PM
fLaMeRED01's Avatar
fLaMeRED01
Very close...
2.0l ATX trannys will bolt up to any SRT block as the SRT-4 and PT-GT blocks are the same. The trick i think you speak of is the PT-GT ECU to run the auto tranny.
There is an SRT here in Hawaii with a strocked 2.6l that pushes 700+whp on race gas. He runs a fully build 1st gen ATX tranny.
Old Apr 23, 2009 | 09:35 PM
djmagic's Avatar
djmagic
the pt will fit. Like everyone said you have to use certain parts. The benefit is it is so much easier to just hook up the whole powertrain at the same time from the same vechile. I thought about it, but would rather have the srt setup
Old Apr 23, 2009 | 11:17 PM
darthroush's Avatar
darthroush
Section Moderator
Originally Posted by fLaMeRED01
Very close...
I've only seen it one time somewhere, so I was kind of guessing from memory. That is probably what it was. Thanks
Old Apr 24, 2009 | 09:08 AM
dtjackten's Avatar
dtjackten
2nd gen neon peace keeper
wasnt that the one that pritty much blew the intercooler apart???
