abs light is on
Old May 5, 2009 | 09:13 AM
jamesmsta's Avatar
jamesmsta
Default abs light is on
i have a 04 neon r/t and the abs light is on. to my knowledge the abs seems to be working fine. i have ran a scanner on it and no codes came up, any ideas?
Old May 5, 2009 | 02:07 PM
darthroush's Avatar
darthroush
Section Moderator
How's your brake fluid? Low? Old?
Old May 6, 2009 | 08:29 PM
jamesmsta's Avatar
jamesmsta
probably been in for the life of the car 40,000 miles. i checked it when it came on and it was on the level.
Old May 6, 2009 | 10:45 PM
darthroush's Avatar
darthroush
Section Moderator
Does the light stay on the entire time or when you are braking?
Old May 7, 2009 | 07:25 AM
jamesmsta's Avatar
jamesmsta
all the time, at first it was hit or miss, coming on mostly when it rained and i hit a puddle. then it started coming on more frequent, and the first stop i took would usually be pretty hairy, as the brakes seemed like they werent there. now it is on all the time, brakes are working fine, but the abs light stays on all the time.
Old May 7, 2009 | 07:26 AM
jamesmsta's Avatar
jamesmsta
are there wires or sensors around the front wheels? maybe i should check there
Old May 7, 2009 | 09:20 AM
darthroush's Avatar
darthroush
Section Moderator
The reason I ask if it came on and off is, if your pads are low, it can cause the ABS light to come on when you are braking. Takes more fluid to push out a low pad, so the fluid could get too low and come on at that point, then go away when you let off the pedal as the reservoir fills back up (speaking from personal experience here).
There are ABS Sensors on each wheel. It does sound like you may want to check those and the wires.
Old May 7, 2009 | 06:45 PM
jamesmsta's Avatar
jamesmsta
the pads can be checked off the list as a suspect they are under 6000 miles old. will check the sensors and wires when i get a chance. dont understand why that wouldnt show on a scanner though.
Old May 7, 2009 | 07:47 PM
darthroush's Avatar
darthroush
Section Moderator
Yeah, I'm not too sure either. I'm don't fully understand what causes everything with ABS, especially the light.
