So, i'm gonna turbo
Old May 28, 2009 | 01:17 PM
  #31
tooslow's Avatar
tooslow
I have adapter there is just one problem with it one of the pins is missing but aint no biggy. send me your e-mail if you want it and I will send you pics
I have basically have a whole kit minus enjecters just laying at my moms If you need anything just let me know I might have it
Old May 28, 2009 | 01:50 PM
  #32
tooslow's Avatar
tooslow
I have too go check what all is missing from it but is pretty complete I would let all of it go for about a $1000 just about every thing from feul system too turbo plus gutted cat. most intercooler piping and intercooler.
Old May 28, 2009 | 02:07 PM
  #33
sarguy01's Avatar
sarguy01
Where are these mystical 8-12 psi numbers coming from?
A tip. Do not run what other people run. Every engine, turbo set up, etc is slightly different and you don't want to blow up your engine. Along with your wideband, get something to watch knock with. Your air/fuel can be good, but if you knock too much - say goodbye to pistons, rings, rods, etc. You may not even know it is knocking enough to destroy the engine.
I think it is a given, but make sure to run 91 octane once you bolt the turbo on.
I know that you can check out a certain forum for used SRT-4 parts. I picked up a stock turbo and manifold for under 100$.
With that, I wish you good luck.
Old May 28, 2009 | 02:31 PM
  #34
Py1stazty's Avatar
Py1stazty
the only problem with getting the turbo and manifold is i spent 375 getting the header, downpipe, and my muffler on, and to put the manifold on would almost be a waste of that money lol...and i got a stupid question, i know you need a an intercooler, but do you need the piping, or is there something in the engine it hooks up to?
Old May 28, 2009 | 02:36 PM
  #35
sarguy01's Avatar
sarguy01
So you are not going to use a TD04 then? What turbo can you put on the manifold you bought?
There needs to be a pipe/tube from the turbo to the intercooler and from the intercooler to the throttle body. It must be able to hold under pressure as well.
Old May 28, 2009 | 02:39 PM
  #36
Py1stazty's Avatar
Py1stazty
i don't know what turbo i'm gonna use, i don't think i can use one with the header i have, i'm jsut at a crossroads with this lol, i thik i might jsut wait it out and get it as cheap as possible, so i can maybe get it for 160 bucks after shipping and not 225
Old May 28, 2009 | 02:46 PM
  #37
sarguy01's Avatar
sarguy01
I hate to tell you, but unless you have a turbo header, which will have a big turbo flange on it, you need another header. You can't just throw a turbo onto any manifold. Your exhaust will most likely not work either.
To put a turbo on your Neon, I would estimate, even if you buy everything used, that you are going to spend at least 1000$, if not 1500+$.
A used wideband is 200$
turbo/manifold - 100$
intercooler/piping/clamps - 100$
injectors - 50$
return line -200$
fuel pump - 100$
exhaust - 200+$
All of the other little stuff that comes up - 250$? 500$?
Old May 28, 2009 | 02:55 PM
  #38
Py1stazty's Avatar
Py1stazty
yea its not a turbo header...this ebay thing i'm looking at has....
turbo, manifold, o2 housing, blow off valve, heat sheild, banjo bolts, stock coolant overflow bottle, oil and coolant lines, and support brackets for the o2 housing and exhaust manifold.
Old May 28, 2009 | 03:06 PM
  #39
Py1stazty's Avatar
Py1stazty
and i've been looking at srt 4 exhausts on ebay as well...
Old May 28, 2009 | 03:28 PM
  #40
tooslow's Avatar
tooslow
don't worry about a exhaust. you can add that later get a adapter the turbofold, then all the pluming intercooler pipes and oil and water fittings then decide what your gonna do for feul since your in florida I would do MS it cost about the same as a return line system but it performs much better. and you don't have too worry about smog testing
