srt 4 guages
Old Mar 13, 2005 | 09:13 PM
eaglesfan4life420's Avatar
eaglesfan4life420
Default srt 4 guages
Hi, i was on ebay a couple of weeks ago and seen the srt-4 guages for sale. Will the install in my 04 sxt without truoble and will the guages be as acccurate??
Old Mar 13, 2005 | 10:52 PM
LowSlowNeon's Avatar
LowSlowNeon
Default RE: srt 4 guages
Yes the cluster is a direct swap from what I hear. I don't know why it wouldn't be.
Old Mar 13, 2005 | 11:37 PM
eaglesfan4life420
damm i knew i should of bought them i think they only sold for like 60 dollars.
Old Mar 14, 2005 | 02:18 AM
casper's Avatar
casper
I see them on there all the time.
Old Mar 14, 2005 | 02:25 AM
LowSlowNeon
Only problem I see with it is the mileage isn't going to be correct. I don't believe there is any way to get it changed. I'm not even sure the dealer can reflash your correct mileage on there.
Old Mar 14, 2005 | 02:27 AM
casper's Avatar
casper
If you buy the cluster from the dealer they will install it and flash the correct milage, other than that you have to report it as not corrct and it will drop the value of the car at sale time.
Old Mar 14, 2005 | 07:18 AM
71RoadRunner's Avatar
71RoadRunner
They will install just fine, but your speedometer will be way off. The SRT-4 speedometer goes up to 160 MPH and the SXT only goes up to 120 MPH, I believe. This will cause your speedometer to be off, it will show you going faster than you actually are, it will read 80 MPH when your actually going 60 MPH. All the other gauges should read right though.
Old Mar 14, 2005 | 12:02 PM
LowSlowNeon
Really? I don't see how that would have any affect on it at all. The SXT is limited to 120 but I don't see why the speedometer would be out of whack.
Old Mar 14, 2005 | 12:33 PM
casper's Avatar
casper
The voltage is gonna be different. At such and such a voltage the sxt is gonna be at 50, srt is gonna be at 60. you might be able to chang the speed sensor and have it work.
Old Mar 18, 2005 | 11:11 PM
LowSlowNeon
I've read about people over on neons.org that have swapped them in there and they read just fine.
