You should all do yourselves a favour...
Old Aug 26, 2009 | 09:54 PM
acid_mojojojo's Avatar
acid_mojojojo
Originally Posted by OhNo2.0
Pull your fuel pump relay to reset the computer (easier then removing terminal)...
For some reason, I did this, then drove it for 50km EASY, not hard like before...and it runs 20x better. Smoother idle, smoother shift, throttle position seemed to have changed to achieve certain speeds and the tick has settled quite a bit.
I have a 03 ATX can you tell me where the fuel pump relay is located so I can try this?
thanks
mojo
Old Aug 27, 2009 | 01:20 AM
darthroush's Avatar
darthroush
Section Moderator
On any Neon, it should be in the fuse box under the hood. Right side of the engine bay. Mine is pulled as I type this...
