which header is better?
Old Mar 22, 2005 | 02:41 AM
  #21
ryanmills06's Avatar
ryanmills06
Default RE: which header is better?
No problem though, thanks for the advice. any is useful. Your way does sound like a good idea. Groundcontrols probabaly works just as well, I just dont have the tools to weld so if i could connect the two exhaust pipes than get them welded at a muffler shop that could possibly work
Old Mar 22, 2005 | 03:23 AM
  #22
GroundControl's Avatar
GroundControl
yea i just took the pic lol. it sounds like his idea will work fine. but your only using 2 bolts to hold the header onto the cat witch had 4 holes for bolts, but it shouldnt matter. it should still work fine tho. my advice is to put the header on first then connect it to the cat. Dont over tighten the header bolts.
Old Mar 22, 2005 | 03:43 AM
  #23
casper's Avatar
casper
Welding it is better. I had to weld my Kirk header on, but that eliminates the cat.
Old Mar 23, 2005 | 12:33 AM
  #24
ryanmills06
Yeah welding would be much better, but I dont have any tools to weld, so what i most likely do is just take it to a muffler shop to get it welded
Old Mar 24, 2005 | 06:57 AM
  #25
casper's Avatar
casper
ORIGINAL: ryanmills06
That would be best.
Old Apr 5, 2005 | 12:13 AM
  #26
Lou808's Avatar
Lou808
i'm having trouble looking for headers for my 2005 dodge neon. i was wonderin if any one knows of one that bolts on and is carb legal?
