Suspension/Lowering ?
Old Mar 24, 2005 | 01:03 PM
lblackneon's Avatar
lblackneon
Default Suspension/Lowering ?
I'm thinking about lowering my car but, I talked to a guy at Midas and he suggested not to. He said it would not be convenient to do that because not anyone (Midas, Tire Kingdom etc.) can align your tires. He said they align your tires by the cars specs. Do u all have to go to a special place to get your tires serviced? Do u have to go to a performance shop or something? Just curious
Old Mar 24, 2005 | 08:25 PM
casper's Avatar
casper
Default RE: Suspension/Lowering ?
I have my car aligned at town fair tire. they use a Hunter alignment machine. They align by laser.
Old Mar 25, 2005 | 12:10 AM
TJW815's Avatar
TJW815
i get mine done at tire discounters, camber is off, but it's good that way, hold corners better
Old Mar 25, 2005 | 01:24 AM
duelsxt's Avatar
duelsxt
I got mine aligned at my work. A dealership. I tuck my factory 15s with a coilover setup, and we put my car under perfect specs. took a while to get it on the rack but it can be done. they just tell you that because it is not worth your 59.95 for them to spend all there time on your car. Ill bet if you thow them some cash they will do it !!![sm=hail.gif]
Old Mar 25, 2005 | 03:33 PM
lblackneon's Avatar
lblackneon
Oh I see.
So some tire places align by the specs of the car and others can align by laser? What's the best way for a lowered car a laser?
Old Mar 25, 2005 | 08:43 PM
casper's Avatar
casper
If they do it by the specs its gonna be off. Laser is the only way to do a lowered car right, or at least the easiest.
Old Mar 27, 2005 | 03:51 AM
ewetho's Avatar
ewetho
There are aftermarket camber bolts available to the shops (probably will charge extra to put them in-we do) that should get them at least close if not the struts don't have slots that alow ajustment. The struts may have an elongated slot that should alow some adjustment (would use this first).If still of then you can have the strut holes elongated to help correct problem. There is a way. Just understand it may cost extra. But hey it already did right? Should be doable.
Old Mar 27, 2005 | 12:05 PM
duelsxt's Avatar
duelsxt
Yea, Are machine is laser but we put it into specs...
