96 head on 01
Old Jul 30, 2009 | 02:02 AM
smallblockfreak's Avatar
smallblockfreak
Default 96 head on 01
is there anything else besides the head and headgasket that i will need? putting a 96 SOHC head on a 01 SOHC.
Old Jul 30, 2009 | 01:10 PM
srtgtr34's Avatar
srtgtr34
1 problem... EGR valve. It has to be blocked off,
A vendor on the .org has a plate for it, i believe.
You will have to use the 1gn valve cover and some sensor wires may need to be lengthened ( not to sure about this one).
Old Jul 30, 2009 | 02:54 PM
KARR's Avatar
KARR
From: In a Lucid Dream. But now I want my life back.
I just noticed oil leaking from the right side of my valve cover. How much is a new head and gasket? I really want this fixed and soon. How much labor is involved?
Old Jul 30, 2009 | 03:42 PM
dtjackten's Avatar
dtjackten
2nd gen neon peace keeper
smallblock, they are interchangeable, that is accually what i am running, u just need to use a block off plate for egr, and MAKE SURE TO CHANGE SENSORS OVER!!!! wiring u can use and also second gen valve cover u can use as well!
Old Jul 30, 2009 | 10:56 PM
contagious19's Avatar
contagious19
+1 i got a 1st gen engine dat im working on. just got to change the sensors and block the egr valve. karr depends on where u go get it done and its a lot of work
Old Jul 31, 2009 | 01:49 AM
smallblockfreak
what sensors? Just the cam position sensor?
Old Jul 31, 2009 | 10:24 AM
dtjackten's Avatar
dtjackten
cam is the major one, coolant temp sensor next to it u have to change as well.... i think the coolant temp is the same, but i am not 100%
Old Jul 31, 2009 | 11:13 AM
smallblockfreak
So i need to use my sensors on the 96 or use 1st gen sensors? Just making sure here.
Old Jul 31, 2009 | 02:16 PM
dtjackten's Avatar
dtjackten
use ur sensors. off the 01
Old Jul 31, 2009 | 05:39 PM
smallblockfreak
alright thanks for the clarification. I'll prolly stop up at your house when i'm home i'll give you a text.
