Tach and Computer Problems
I just bought a tach for my 2003 Dodge Neon SE since it didn't come with one stock. But my friend and I haven't been able to find the computer so that we can install the tach. I removed the entire from dash and I don't see it. I haven't done a lot of work with cars so I'm pretty new to this. Where can I find the computer/ECU?
they are tricky.. prolly would be easier to call the dealer and ask but if they don't know im sure you can find it online some where.... u can try the repair guide on the AutoZone website. i seen the behind the bump and even inside the dash hidden... they place them all over the car i dunno why.
ORIGINAL: casper
I am not sure about the 2nd gen, but on the 1st gen its in the engine bay by the drivers fender well.
i am in the situation as you, i have an se and bought a tach, but you need to buy a tach adapter to get it to work, me and this mechanic from the dodge dealership in my town worked on it. we could only get it to read half rpm when hooked up to what i think was the coil, not sure, but he had the whole wiring map for the whole car.
Mine is on the drivers fender well on my 98. I had the same problem with my tach, it only read half rpm. Neons have a dual coil pack, so you can't run the pickup to the coil. I have mine connected to the wire from the PCM and its fine with no tach adapter. Some tachs do require an adapter, but that varys brand to brand.
Trending Topics
before i spend the money for a new cluster pod at a junk yard. is it true when u take out the old one there is already a tach wire there to put in the new pod ?? cuz my alarm is in my dash so it takes some work to get the dash off.
