detailed stereo installation?
#31
#32
I have a Klein Tools Wire Stripper and Wire Crimper. Separate tools for each step has been the best money I've spent as far as tools for wiring work goes. The all-in-ones try to combine the above, but fail miserably at it. Those along with my mini-torch for heat-shrink pieces and exterior connectors FTW.
#33
well i got it!! it took a long time!! but well worth it! i had a wire stripper and clamper tool that did fine and got the job done.
the hardest part was getting the power wire through the grommet, the rest went slow but easy, just had to be carful removing panels. but its done!!
when i bump it, it dims my headlights.. but its not a completely powerful system.. is it maybe a bad battery, should i get a farad cad, or maybe poor grounding? iffy alternator?
#34
#35
Mine did the headlight thing pretty noticeably until I changed the belts that were on their way out. Been pretty much fine since. Now I just have to replace the alternator that went out yesterday. A big part of the problem from my understanding is the grounds in the car. A lot of people upgrade all of the grounds to larger wire. The "super ground" upgrade I believe is what they call it.
#36
#37
