shifting
Old Nov 17, 2009 | 09:16 PM
cassidy's Avatar
cassidy
Default shifting
Wife was driving her 04 sxt home tonight and said that she was driving down the road normally and the engine was reving higher than normal. She said that she thought she was in the wrong gear but she looked and it was in the correct gear. She left work and was going up a hill directly after turning onto that road, and the car was stone cold and it is getting cold around here. After stopping at a light she said it acted normally, do these cars hold a gear longer when cold to help speed warm up?
Old Nov 18, 2009 | 04:55 AM
darthroush's Avatar
darthroush
Section Moderator
Depending on the temperature of the transmission, it will only use/allow certain gears. Sounds normal thus far anyways
Old Nov 18, 2009 | 10:26 AM
LowSlowNeon's Avatar
LowSlowNeon
It sounds pretty normal to me as well. The hill will most likely make the car downshift or keep it at a higher rpm until you get by the hill or ease off the gas. I have to downshift all the time to keep my car going a constant speed. There are a lot of big hills around here.
Old Nov 18, 2009 | 10:55 AM
AnthemBassMan's Avatar
AnthemBassMan
-Yep. Mine won't shift into overdrive until the tranny warms up a bit, even on level ground. It might take a couple miles if it gets really cold out. Done it ever since we bought the car with 19k on it.
L8R,
Matt
Old Nov 19, 2009 | 03:57 PM
Franklinnn's Avatar
Franklinnn
I remember reading in the repair guide that the engine temprature has a huge impart too.
like it had a chart, and around cold temps there is a hard shift between 2 and 3, but just keep your eyes open for slipping transmission.
