'04 Neon Problems
Old Jan 13, 2010 | 02:03 PM
Fireneko's Avatar
Fireneko
Question '04 Neon Problems
Hello everyone! I have a 2004 Neon and it started having problems a couple of days ago. The check engine light came on and would not go off when I cut the car off and started it up again. So I decided to try to get it back to the house from where I was. It was about 15 miles tops.......anyways it started jerking while I was on the highway and hit about 60. So I backed off and it did ok until I got in stop and go traffic. Every time starting off from a stop light I would have to ease on the gas other wise it would just jerk and once it got up to about 35 it would start jerking again. It didn't overheat and it wasn't smoking or anything else.....just the light and the jerking. All I've been able to find online in regards to this is anything from a simple Fuel filter to the transmission. I was more or less just wondering what would cause it to do this? And would it be something that I could easily fix or a costly repair?
Old Jan 13, 2010 | 05:02 PM
bg1995redneon's Avatar
bg1995redneon
Do the Dodge Key dance. Insert the key and turn it to on then back to off quickly three times. When you turn it back to on the next time, watch the Check Engine light. It will blink. There will be a series of blinks pauses and blinks. Each time it pauses, the number of blinks before the pause is one digit of a two digit error code.
Blink Blink pause blink blink is error code 22. There may be multiple error codes, so be ready. Error codes 12 and 55 can be ignored completely and you won't have error code 12 unless you have disconnected the battery within the last 50 key on/off cycles.
Since the car will run, immediately go to an Autozone, Advance, OReilly, NAPA, etc. parts store and get them to give you a free ODB-II read on your error codes. Write them down.
These error codes can be looked up on either the 2nd Generation Neon forum, or unless 2nd Gen specific, this forum. Come back and give us the error codes so we can be of more help.
Old Jan 13, 2010 | 05:07 PM
bg1995redneon
BTW, and just so you know. The Dodge key dance error code check is not a one time thing. If you think you got it wrong, or missed one, or whatever, just turn the switch off, do the 3 times on/off dance, and watch the codes repeat themselves. Do it several times if you need to to get all the error codes.
The actual error codes will not go away until you either fix the problem and reset the computer, or just reset the computer, but for heavens sake don't do that until you get the codes and don't let the guy at the parts store do it either.
Sounds like you crankshaft or camshaft position sensors are getting wonky, or you are having misfires, but that is what the error codes are for.
Old Jan 13, 2010 | 06:19 PM
neoncrazy101's Avatar
neoncrazy101
Since you have an 04', you have a digital odometer and the engine codes will actually display on the odometer in the Pxxxx fashion instead of the check engine light blinking.
Old Jan 14, 2010 | 10:14 AM
bg1995redneon
Wow. That is WAY nicer in that you won't even need to go to Autozone to get the detailed error codes!
I guess Dodge decided to give 2nd gen'ers more information then was possible for 1st gen'ers.
Nice. Good to know. WAY better then counting blinks......
Old Jan 14, 2010 | 09:08 PM
Fireneko's Avatar
Fireneko
Default Thanks guys!
Thanks guys! I didn't know Autozone even had something like that! I took it up there and it turns out it is the Camshaft sensor. It doesn't look like it's going to be to hard to replace. Thanks for the info!
Old Jan 15, 2010 | 06:50 PM
Altima_wb's Avatar
Altima_wb
Or you could just spend 20 bucks on a repair manual that has the codes in it... and honestly if you work on your car yourself you should have the manual anyway...
Old Jan 16, 2010 | 01:36 AM
Ghost Neon 2's Avatar
Ghost Neon 2
03-04 neons
P0016-CRANKSHAFT/CAMSHAFT TIMING MISALIGNMENT
P0031-O2 SENSOR 1/1 HEATER CIRCUIT LOW
P0037-O2 SENSOR 1/2 HEATER CIRCUIT LOW
P0032-O2 SENSOR 1/1 HEATER CIRCUIT HIGH
P0038-O2 SENSOR 1/2 HEATER CIRCUIT HIGH
P0033-SURGE VALVE SOLENOID CIRCUIT
P0068-MANIFOLD PRESSURE/THROTTLE POSITION CORRELATION
P0071-AMBIENT TEMP SENSOR PERFORMANCE
P0072-AMBIENT TEMP SENSOR LOW
P0073-AMBIENT TEMP SENSOR HIGH
P0107-MAP SENSOR LOW
P0108-MAP SENSOR HIGH
P0111-INTAKE AIR TEMPERATURE SENSOR PERFORMANCE
P0112-INTAKE AIR TEMPERATURE SENSOR LOW
P0113-INTAKE AIR TEMPERATURE SENSOR HIGH
P0116-ENGINE COOLANT TEMPERATURE PERFORMANCE
P0117-ENGINE COOLANT TEMPERATURE SENSOR LOW
P0118-ENGINE COOLANT TEMPERATURE SENSOR HIGH
P0122-THROTTLE POSITION SENSOR #1 LOW
P0123-THROTTLE POSITION SENSOR #1 HIGH
P0125-INSUFFICIENT COOLANT TEMP FOR CLOSED-LOOP FUEL CONTROL
P0128-THERMOSTAT RATIONALITY
P0129-BAROMETRIC PRESSURE OUT-OF-RANGE
P0131-O2 SENSOR 1/1 VOLTAGE LOW
P0137-O2 SENSOR 1/2 VOLTAGE LOW
P0132-O2 SENSOR 1/1 VOLTAGE HIGH
P0138-O2 SENSOR 1/2 VOLTAGE HIGH
P0133-O2 SENSOR 1/1 SLOW RESPONSE
P0139-O2 SENSOR 1/2 SLOW RESPONSE
P0135-O2 SENSOR 1/1 HEATER PERFORMANCE
P0141-O2 SENSOR 1/2 HEATER PERFORMANCE
P0171-FUEL SYSTEM 1/1 LEAN
P0172-FUEL SYSTEM 1/1 RICH
P0201-FUEL INJECTOR #1
P0202-FUEL INJECTOR #2
P0203-FUEL INJECTOR #3
P0204-FUEL INJECTOR #4
P0234-OVERBOOST PERFORMANCE
P1106-BARO SOLENOID PERFORMANCE
P1188 TIP SENSOR PERFORMANCE
P0243-WASTEGATE SOLENOID CIRCUIT
P0300-MULTIPLE CYLINDER MISFIRE
P0301-CYLINDER #1 MISFIRE
P0302-CYLINDER #2 MISFIRE
P0303-CYLINDER #3 MISFIRE
P0304-CYLINDER #4 MISFIRE
P0315-NO CRANK SENSOR LEARNED
P0325-KNOCK SENSOR #1 CIRCUIT
P0335-CRANKSHAFT POSITION SENSOR CIRCUIT
P0339-CRANKSHAFT POSITION SENSOR INTERMITTENT
P0340-CAMSHAFT POSITION SENSOR CIRCUIT
P0344-CAMSHAFT POSITION SENSOR INTERMITTENT
P0420-CATALYTIC 1/1 EFFICIENCY
P0440-GENERAL EVAP SYSTEM FAILURE
P0441-EVAP PURGE SYSTEM PERFORMANCE
P0442-EVAP SYSTEM MEDIUM LEAK
P0443-EVAP PURGE SOLENOID CIRCUIT
P0452-NVLD PRESSURE SWITCH SENSE CIRCUIT LOW
P0453-NVLD PRESSURE SWITCH SENSE CIRCUIT HIGH
P0455-EVAP SYSTEM LARGE LEAK
P0456-EVAP SYSTEM SMALL LEAK
P0461-FUEL LEVEL SENSOR #1 PERFORMANCE
P0462-FUEL LEVEL SENSOR #1 LOW
P0463-FUEL LEVEL SENSOR #1 HIGH
P0480-COOLING FAN 1 CONTROL CIRCUIT
P0481-COOLING FAN 2 CONTROL CIRCUIT (NON-TURBO)
P0481-COOLING FAN 2 CONTROL CIRCUIT (TURBO)
P0498-NVLD CANISTER VENT VALVE SOLENOID CIRCUIT LOW
P0499-NVLD CANISTER VENT VALVE SOLENOID CIRCUIT HIGH
P0501-VEHICLE SPEED SENSOR #1 PERFORMANCE (AUTO TRANS)
P0501-VEHICLE SPEED SENSOR #1 PERFORMANCE (MANUAL TRANS)
P0506-IDLE SPEED LOW PERFORMANCE
P0507-IDLE SPEED HIGH PERFORMANCE
P0519-IDLE SPEED PERFORMANCE
P0508-IAC VALVE SENSE CIRCUIT LOW
P0509-IAC VALVE SENSE CIRCUIT HIGH
P0513-INVALID SKIM KEY
P0516-BATTERY TEMPERATURE SENSOR LOW
P0517-BATTERY TEMPERATURE SENSOR HIGH
P0522-OIL PRESSURE SENSOR LOW
P0551-POWER STEERING SWITCH PERFORMANCE
P0562-BATTERY VOLTAGE LOW
P0563-BATTERY VOLTAGE HIGH
P0572-BRAKE SWITCH #1 CIRCUIT LOW
P0573-BRAKE SWITCH #1 CIRCUIT HIGH
P0581-SPEED CONTROL SWITCH #1 HIGH
P0582-SPEED CONTROL VACUUM SOLENOID CIRCUIT
P0586-SPEED CONTROL VENT SOLENOID CIRCUIT
P0594-SPEED CONTROL SERVO POWER CIRCUIT
P0600-SERIAL COMMUNICATION LINK
P0601-INTERNAL MEMORY CHECKSUM INVALID.....Basically...PCM problem.
P0622-GENERATOR FIELD CONTROL CIRCUIT
P0627-FUEL PUMP RELAY CIRCUIT
P0630-VIN NOT PROGRAMMED IN PCM
P0632-ODOMETER NOT PROGRAMMED IN PCM
P0633-SKIM KEY NOT PROGRAMMED IN PCM
P0645-A/C CLUTCH RELAY CIRCUIT
P0660-MANIFOLD TUNE VALVE SOLENOID CIRCUIT
P0685-ASD RELAY CONTROL CIRCUIT
P0688-ASD RELAY SENSE CIRCUIT LOW
P0700-TRANSMISSION CONTROL SYSTEM
P0833-CLUTCH RELEASED SWITCH CIRCUIT
P0850-PARK/NEUTRAL SWITCH PERFORMANCE
P1105-TIP SENSOR SOLENOID CIRCUIT
P1115-GENERAL TEMP SENSOR PERFORMANCE
P1189-TIP SENSOR CIRCUIT LOW
P1190-TIP SENSOR CIRCUIT HIGH
P1390-CAM AND CRANK SIGNALS DO NOT MATCH
P1593-SPEED CONTROL SWITCH STUCK
P1602-PCM NOT PROGRAMMED
P1603-PCM INTERNAL DUAL-PORT RAM COMMUNICATION
P1604-PCM INTERNAL DUAL-PORT RAM READ/WRITE INTEGRITY FAILURE
P1607-PCM INTERNAL SHUTDOWN TIMER RATIONALITY
P1696-EEPROM MEMORY WRITE DENIED/INVALID
P1697-EMR (SRI) MILEAGE NOT STORED
P1854-TIP BARO OUT OF RANGE
P2074-MANIFOLD PRESSURE/THROTTLE POSITION CORRELATION
- HIGH FLOW/VACUUM LEAK
P2096-DOWN STREAM FUEL SYSTEM 1/2 LEAN
P2097-DOWN STREAM FUEL SYSTEM 1/2 RICH
P2302-IGNITION COIL #1 SECONDARY CIRCUIT-INSUFFICIENT
IONIZATION
P2305-IGNITION COIL #2 SECONDARY CIRCUIT-INSUFFICIENT
IONIZATION
P2503-CHARGING SYSTEM VOLTAGE LOW
U0101-NO TRANSMISSION BUS MESSAGE
U0155-NO CLUSTER BUS MESSAGE
U0168-NO SKIM BUS MESSAGES
U110C-NO FUEL LEVEL BUS MESSAGE
Old Jul 5, 2011 | 12:46 AM
Nathalie's Avatar
Nathalie
2004 Dodge Neon - Recent History: check engine light on paired with car shaking when going over 55mph, gears sticking - three OBD codes : P0498, P0499, P0--- : replaced camshaft sensor > no more shaking, gears shifting smoothly, two latter OBD codes gone. The following week, oil leak and persistent P0498 = NVLD canister vent valve solenoid circuit low. Cannot find source of leak. Took to a mechanic, said it is the head gasket. Found that the mechanic was lying about 3 other supposed repairs the car "needs" - along with the supposed cost of parts. Another mechanic looked at it - said it doesn't need a head gasket repair - seeing that there is no water or antifreeze coming out of the tail pipe (we did not do any pressurized tests however). Oil leak - replaced the oil pressure sending unit - thinking this was a possible leak source. Leak persists and a p0522 (oil pressure sensor low) is added along with p0498 (NVLD canister vent valve solenoid circuit high - CONtradiction of other code). Also - when looking at engine from below while someone was running through the gears, my engine SHIFTS (moves/tilts) as it goes from P to N to D. Any insights?
Old Jun 5, 2012 | 09:16 PM
bigred2005's Avatar
bigred2005
Did u ever find out what the problem was. My 2005 neon se does the exact same thing .
