need help asap (parking lights not working)
Old Feb 7, 2010 | 08:16 PM
twk62390's Avatar
twk62390
Default need help asap (parking lights not working)
i was wiring some fog lights in to my parking lights today and when i went to check them two wires touched and shorted out, but no fuses blew. i have checked and rechecked. my parking lights, and cluster lights are not working. is it possible that something in the switch lever fried and a new one will fix it. my headlights do work tho.
Old Feb 7, 2010 | 09:16 PM
The Black Stig's Avatar
The Black Stig
Check the relay
Old Feb 7, 2010 | 09:45 PM
twk62390's Avatar
twk62390
how do i do that?
Old Feb 7, 2010 | 10:53 PM
The Black Stig
I suggest you buy a Haynes Repair manual ..... In a nay event i'' search and find some info and get back to you tomorrow.
Old Feb 7, 2010 | 11:02 PM
twk62390's Avatar
twk62390
I have one, and it doesnt help. and ive searched all over the place and the problem is always the fuse, in mine its not the case. so if youre going to be a dick dont even post. its not like i have time to mess around because this is my only transportation and i have work tomorrow and will be driving the car at night
Old Feb 7, 2010 | 11:19 PM
darthroush's Avatar
darthroush
Section Moderator
I think he was suggesting a manual so you could find the relay and or test it. As for you "searching all over the place and the problem always being the fuse, but it's not in your case," well, you just disproved your own argument. Congrats. Who knows. Maybe it isn't the relay either. Maybe you fried your expensive MFS.
Old Feb 8, 2010 | 06:56 PM
srtgtr34's Avatar
srtgtr34
It really sounds like the fuse blew, even though you said you checked it, its highly unlikely that the a fused circuit grounded out and didn't blow the fuse. You checked the fuse box inside the car on the side of the dash right?
Old Feb 13, 2010 | 03:23 PM
Franklinnn's Avatar
Franklinnn
why would you run your parking lights into your fogs?
you should have boughten a used (or new) MFS, and done the wiring the right way, the wires for the parking lights are not meant to run fogs too. but im with darth here, it could be the MFS, or a relay but would lean twards the MFS
Old Feb 15, 2010 | 11:59 PM
Moparkyle's Avatar
Moparkyle
To clarify the MFS they are referring to is the multi-function switch.
Old Feb 17, 2010 | 09:47 PM
Twkdout066's Avatar
Twkdout066
It depends on where he was tapping into the wiring as to whether or not the fuse would blow. It would make sense that if no fuses are blown that you need to look into buying a new MFS.
