3 speed automatic?
Old Apr 5, 2010 | 07:21 PM
JADEN's Avatar
JADEN
Default 3 speed automatic?
looking to purchase a driver side axle and i was ask do i have a 3 speed automatic..i have a 2000 neon automatic.so do i have 3 speed hmmm
Old Apr 5, 2010 | 08:41 PM
darthroush's Avatar
darthroush
Section Moderator
I believe you should- IIRC, the 4 speed was available in 2002. Easy way to tell too is if you have a "D" on the shifter pattern, or a "D" with a circle around it. 3 speed transmissions, as far as I know, don't have overdrive so you would just have a D with no circle.
Old Apr 6, 2010 | 11:24 PM
bullitt91's Avatar
bullitt91
i have had a 2002 and a 2001 first year for the 4spd was 2002 yours is a 3spd. has D then 2 then L
Old Apr 7, 2010 | 10:20 AM
l_pillon's Avatar
l_pillon
definatly a 3 spd im in the same boat 2000 neox lx here..
Old Apr 7, 2010 | 05:39 PM
JADEN's Avatar
JADEN
thanks alot guys..now another question how different is the 3 spd axle and 4 spd axle differ from a 2000 to a 2002 also whats a goo d axle you guys recommend.thanks again
Old Apr 7, 2010 | 11:52 PM
darthroush's Avatar
darthroush
Section Moderator
A direct replacement should be just fine. Just buy one for your year and be done with it. If there is one for 2000-2001 and then 2002-2005 when the two different transmissions were used, that'll answer your question.
Old Apr 10, 2010 | 10:54 AM
JADEN's Avatar
JADEN
thanks guys.thread is closed..
