Oil in intake manifold and spark plug Wells
Old May 15, 2010 | 04:40 PM
Streetuner's Avatar
Streetuner
Unhappy Oil in intake manifold and spark plug Wells
I have a 2002 Dodge Neon Base (420a SOHC) with a hahns Race Craft turbo kit on it (recently installed). Months after installing the kit my car had issues starting, while changing the plugs I discovered oil in the spark plug wells. Has n e 1 installed a hahns kit or had a similar issue with a turbo neon? ***Additional Note "I discovered oil in my intake manifold as well"
Old May 15, 2010 | 06:38 PM
darthroush's Avatar
darthroush
Section Moderator
The spark plug tubes are coming out, and/or the seals are bad under the valve cover.
Old May 17, 2010 | 09:29 PM
kabuk1's Avatar
kabuk1
ive only ever had this problem(with both turbo & non turbo neons) when my valve cover gasket was blown. had it happen in my srt4 and my 99 SOHC.
Old May 18, 2010 | 02:35 AM
contagious19's Avatar
contagious19
do you have a oil catch can in between the intake and the pcv valve?
Old May 18, 2010 | 07:17 PM
darthroush's Avatar
darthroush
Section Moderator
Good call. Missed the intake manifold part. On a boosted Neon, you'll need one of these for sure.
Old May 23, 2010 | 09:43 PM
ccexpress2002's Avatar
ccexpress2002
I need to do the catch can. Does anyone have pics of what it should look like when done?
Old May 24, 2010 | 02:38 AM
darthroush's Avatar
darthroush
Section Moderator
PCV Valve ==== |Catch Can| ==== Intake
Make sure to get chemical resistant (gas) tubing.
Old May 24, 2010 | 11:12 AM
ccexpress's Avatar
ccexpress
Where would be a good place to get the catch can?
Old May 24, 2010 | 11:40 AM
showsxt's Avatar
showsxt
ebay or turbo neon store online. THats where I got mine when I had my 1st gen turboed with a hahn stage 2 kit .
Old May 24, 2010 | 03:13 PM
ccexpress's Avatar
ccexpress
Found one on ebay thanks.
