windshield washer fluid pump failure
Old 05-20-2010 | 03:06 PM
snake425's Avatar
snake425
Default windshield washer fluid pump failure
05 sxt neon I have a windshield washer pump that does not work, which fuse is it on; is it the same as the wipers? (wipers still work) How do you recommend getting to the pump? Where would you recommend finding a new pump?
Old 05-20-2010 | 03:27 PM
Moparkyle's Avatar
Moparkyle
I had the same thing happen, the washer reservoir is on the right side up towards the front bumper. When I would pull the switch back the wipers would work but no fluid came out, I could still hear the pump motor spinning. I got under the car to check and the little plastic nipple that the hose that goes to the sprayers connects on was broken.
You can get a new pump around $50-80 and they are real easy to install, shouldn't take you more than 20 minutes.
Old 05-20-2010 | 10:53 PM
darthroush's Avatar
darthroush
Section Moderator
Junk Yard for the pump. It's not an item that commonly goes out.
Quick Reply: windshield washer fluid pump failure
