help plz
Old May 26, 2010 | 05:46 PM
77warlock's Avatar
77warlock
Default help plz
ok so i have a 00 neon and well i dont know what excatly happend to it, but i wasnt driving it. so no about 4 months later i need a car again and im trying to fix it. soo its overheating baddd. i have changed the thermostat, thermostat housing, flushed the radiator, and checked the water pump. non of these have fixed the problem of it overheating. i doubt its the head gasket becuase there is no fluid in the oil. soo any ideas?????
Old May 26, 2010 | 06:13 PM
darthroush's Avatar
darthroush
Section Moderator
A clogged system?
Old May 26, 2010 | 07:12 PM
77warlock's Avatar
77warlock
naw when i had the radiator flushed they did the whole cooling system as well
Pablodragon's Avatar
Pablodragon
possibility of the heater core?
I hope it isn't, for your sake, but I went thru it.
Overheating... went thru 2 radiators, 2 thermostats..water pump and timing belt, then found out I needed a new heater core
Is a giant PITA to replace yourself and a BIG expense if someone does it for you.
whole dash and steering column have to come out to get to it
Old May 26, 2010 | 07:53 PM
77warlock's Avatar
77warlock
hmm well fml....i might just sell the piece. lol
Old May 27, 2010 | 10:02 AM
99avngr's Avatar
99avngr
It is a big possibility it could be your head gasket. Just because theres no fluid in the oil dosent mean anything.
Old May 28, 2010 | 10:14 AM
houndog97's Avatar
houndog97
Can't you bypass the heater core?
Old May 28, 2010 | 03:49 PM
darthroush's Avatar
darthroush
Section Moderator
Yes, you just won't have a heater.
Old May 29, 2010 | 08:05 AM
houndog97's Avatar
houndog97
I'm saying to see if it's the cause of the problem.
Old May 29, 2010 | 03:17 PM
darthroush's Avatar
darthroush
Section Moderator
Oh, got ya.
