where to find?
Old Jun 17, 2010 | 08:34 PM
neon marine's Avatar
neon marine
Default where to find?
Hey guys, does anyone know where I can find a leak detection pump for my 2003 dodge neon sxt?
Old Jun 17, 2010 | 08:47 PM
Moparkyle's Avatar
Moparkyle
Most likely a dealer only item, I've looked at most parts stores for them, but no luck.
Old Jun 17, 2010 | 10:00 PM
darthroush's Avatar
darthroush
Section Moderator
Dealer, junk yard or eBay. Parts stores won't carry this.
Old Feb 26, 2011 | 07:12 PM
jake122288's Avatar
jake122288
where is the leak detection pump located on the vehicle. I have a 2001 dodge neon. I got a check engine trouble code for a pinched line for the evap system and so far my research leads me here. Would this be the cause of my gas gauge dropping as i drive and then if i shut the car off for 1 hour or more it will properly read my gas level when i restart it.
Old Feb 26, 2011 | 08:41 PM
22DODGE22's Avatar
22DODGE22
No. Gage measures liquid volume not vapors.
Old Feb 27, 2011 | 12:12 PM
jake122288's Avatar
jake122288
but it could be the reason for the evap line pinched code and i would still like to know where its located on the vehicle? how hard is it to access? and what could cause the gas gauge problem?
Old Feb 27, 2011 | 02:46 PM
Moparkyle's Avatar
Moparkyle
By the right rear wheel behind the fuel tank.
Old Feb 27, 2011 | 04:47 PM
darthroush's Avatar
darthroush
Section Moderator
What code are you referring to?
Old Feb 27, 2011 | 06:55 PM
hemi4spd's Avatar
hemi4spd
LDP is located on a bracket near right rear swaybar mount
