Help with Transmission part in picture
Hey guys,
I'm trying to figure out exactly what part that is where the plug with the 4 next to it goes on the transmission. This is a picture of a 2003 Neon transmission.
None of the 4 connectors attaches to the TCM, but the wires from them go to the TCM... the cut off wire right next to #4 arrow goes to the TCM.
#1 solenoid pack
#2 input speed sensor
#3 output speed sensor
The #4 is for the range sensor (PRNDL switch)
#1 solenoid pack
I know, I just didn't think I'd need to spell it out. You can clearly see the connector goes to the transmission, with wires going in the other direction. Guess I had to spell it out now after all.
ya, sometimes you sure need to spell it out even when there's a crystal clear picture.
I've been getting mods threatening to ban me for comments less than you stated.. oh well that's typical
..... beat up on the knowledgeable so the less fortunate feel better about their inabilities
I guess if you want it crystal clear, the wires run to the PCM since 03+ TCM's are integrated into the PCM.
Trending Topics
I swore I GAVE the answer just a couple posts from the question.
