humming noise/ new timing belt
Old Oct 21, 2010 | 12:22 AM
Nicholas_Scott's Avatar
Nicholas_Scott
lol no it shouldn't be slowed down. it works fine or me.
want me to send it to an email? haha
Old Oct 21, 2010 | 01:20 AM
darthroush's Avatar
darthroush
Section Moderator
When I watched it, twice to make sure, it sounds like there is a voice, but it sounds really s...l...o...w and deep like it was slowed down, lol. I'm not sure how else to describe it. I can tell you my new belt did not as has not whined and a bad/worn pulley bearing will whine. It sure wouldn't hurt to replace that one pulley though at timing belt time.
Old Jul 27, 2011 | 05:05 PM
Lost4202010's Avatar
Lost4202010
Default Hope this post isnt dead.
Ive got the same problem with my 05 Sxt. Ever solved?
Old Jul 27, 2011 | 06:26 PM
darthroush's Avatar
darthroush
Section Moderator
Some cars just make more noise after a timing belt replacement. No one knows why...
Old Oct 15, 2011 | 05:01 PM
loserbaby's Avatar
loserbaby
I'm getting the same thing after changing my timing belt, a bit annoying in the lower gears but isn't so apparent on the freeway. I'm a long time mechanic and pretty damn sure it all went back together as advertised... I'm gonna run it and see what falls out.
Old Oct 16, 2011 | 12:40 PM
Lost4202010
Cool solved timing humm
Fixed mine already. The problem (if its the same one i had) is that the timing tensioner is set past tolerance and its causing drag which is the noise you hear. loosen the tensioner bolt and reset the tensioner but dont set it to tight or youll still here that humm. in the end the belt should feel slightly loose but not loose enough to jump time or affect throttle response. also if all else fails have someone look over your work. "two heads are better then one" GOOD LUCK
Old Oct 16, 2011 | 04:01 PM
darthroush's Avatar
darthroush
Section Moderator
Good to know. I've never seen an actual fix for the noisiness after a belt/tensioner change. Thanks for reporting back!
Old Oct 17, 2011 | 09:54 AM
loserbaby's Avatar
loserbaby
Not the answer I wanted to hear... ill try it and report back.
Old Oct 17, 2011 | 11:47 PM
loserbaby's Avatar
loserbaby
Blamm,
thanks to this guy, "Lost4202010" I retensioned my timing belt, according to the manual this time. It seems to be working as advertised. I negated to actually read the manual and cranked the tensioner until it ratcheted, then gave it a couple of more clicks to make sure I was there... sinched it down and slammed it back together. It sounded like that little Neon had gear drive! I had in fact, over tensioned the belt, the difference was noticable, and the outcome,... the whining noise is gone, and I feel a bit better about it making it to it's next change interval....
Thanks,
