Light dimming.
Old Jan 24, 2011 | 01:36 AM
Tman52's Avatar
Tman52
Default Light dimming.
I have an aftermarket stereo, and speakers, and I'm wired for subs. So I used to be able to run any volume without power problems. Now I'm at volume level 10 and any higher than that, my stereo will shut off. When teh stereo is on all interior lights are dimmed with just that.
So my thoughts are that my alternator is going out. I just want to verify before I buy a new Alternator.
Old Jan 24, 2011 | 02:32 AM
darthroush's Avatar
darthroush
Section Moderator
Have you checked engine ground resistance?
Old Jan 24, 2011 | 12:47 PM
hemi4spd's Avatar
hemi4spd
after you check the ground, measure the output of the alt (when running you should see close to 14V)
Old Jan 26, 2011 | 09:11 PM
Tman52's Avatar
Tman52
Alright, the ground check is gonna be in my manual?
Old Jan 26, 2011 | 10:02 PM
showsxt's Avatar
showsxt
You can always have your alternator checked at an autoparts store for free thats what I did with mine and my sxt was doing what yours is and it ended up being my alternator was fried.
Old Jan 26, 2011 | 10:46 PM
darthroush's Avatar
darthroush
Section Moderator
You use a multi-meter and measure resistance on the ground wires. The lower the better.
Old Jan 26, 2011 | 11:36 PM
Tman52's Avatar
Tman52
She's going to a shop soon, I got a check engine light today, I have a cylinder misfiring, and the ignition coils I guess need replaced. Anyone wanna guestimate this repair cost?
Old Jan 26, 2011 | 11:41 PM
hemi4spd's Avatar
hemi4spd
dont replace the coil untill u confirm its bad
these things will miss when they get a little oil on the plugs
what code do you have that brought up the CEL?
Old Jan 26, 2011 | 11:48 PM
Tman52's Avatar
Tman52
I just took her to autozone, and had them pull the codes, they told me coils and misfire.
Old Jan 26, 2011 | 11:49 PM
Tman52's Avatar
Tman52
I think I sucked up some water with my CAI (please, no one start an arguement) but yea, I think that caused the misfire for sure.
