srt4 speedo into sxt
Old Mar 21, 2011 | 10:51 AM
srt4rez's Avatar
srt4rez
Default srt4 speedo into sxt
Just over the weekend, I swapped out my sxt speedometer with a srt4 gauge. Everything hooked up well, except when I turned on the car, the brake and abs lights came on and remained to stay on. My question is...is this normal, since the srt4 came with rear disc brakes? It continued to light, so I just pulled the 2 lights from the brake and abs.Everything else is running normal. What do you think?
Old Mar 21, 2011 | 11:09 AM
showsxt's Avatar
showsxt
Yes I think thats normal I think I remember right some others who have done the srt cluster had the same lights come on.
Old Mar 22, 2011 | 12:04 AM
darthroush's Avatar
darthroush
Section Moderator
Normal.
Old Mar 24, 2011 | 03:09 PM
srt4rez's Avatar
srt4rez
Should the cruise control still be working? It lights up but I mean the actual process after the srt installment. Mine isn't going into cruise control after the swap. I don't know if it's due to the changing of panels or not. It was working before, with the stock panel. Let me know.
Old Mar 24, 2011 | 03:21 PM
darthroush's Avatar
darthroush
Section Moderator
Shouldn't have affected that AFAIK. If you swap the old cluster back in, does it still work? Process of elimination...
Old Mar 25, 2011 | 05:31 PM
srt4rez's Avatar
srt4rez
Must have been a small glitch...it's back to working again! I still have the srt cluster installed. It used to do that with the stock cluster too.
Old Jul 17, 2011 | 11:49 AM
blueneon413's Avatar
blueneon413
If you swap out the cluster to a srt4 cluster does the speed read correctly or does it read wrong?
Old Jul 17, 2011 | 04:07 PM
darthroush's Avatar
darthroush
Section Moderator
It's fine.
