Front exterior door handle sticks out after opening
Old Mar 21, 2011 | 11:01 PM
jchabot2012's Avatar
jchabot2012
Default Front exterior door handle sticks out after opening
Both my front exterior door handles, when pulled, do not go back into place. I have to push them back in to get the door to close. My car is a 2002 Dodge Neon SXT. Will I have to take the door panel off and check the release mechanism or is there an easier way? You can email a response at jchabot2012@gmail.com I'm new to the forum and thanks for any replies.
Old Mar 24, 2011 | 02:41 PM
jchabot2012
So I went ahead and took the door panel off and tried to get access to where the mechanism is to the exterior door, but there is a plate of glass and I cannot get to it. I squirted into the door handle holes with WD-40 and tried working the handle, but it didn't help matters. Any ideas?
Old Mar 24, 2011 | 03:17 PM
darthroush's Avatar
darthroush
Section Moderator
Roll up the window, and then the glass won't be in the way?
Old Mar 24, 2011 | 03:49 PM
jchabot2012
Haha, I didn't even make that connection that it was the glass from my window, stupid me. I ended up spraying WD-40 and it didn't work at first but after sitting for a few minutes and then working the handle it seemed to fix the problem. Thanks for your reply.
Old Mar 24, 2011 | 04:27 PM
darthroush's Avatar
darthroush
Section Moderator
If you get some free time, it still might be worth taking the door panel off again and spraying everything from the inside too. You'll likely get even better results that way.
