2005 Dodge Neon stalling problem
Old Mar 24, 2011 | 11:17 AM
rlporter's Avatar
rlporter
Default 2005 Dodge Neon stalling problem
Car starts and idles fine but when you hit the brake pedal engine starts to sputter and dies. Or if you tap the brake and put it in reverse quickly it dies. I've changed the cam sensor and still the same problem. Any help on this?
Old Mar 24, 2011 | 12:18 PM
buddhaman's Avatar
buddhaman
you could have a vacuum leak. any codes popping up?
Old Mar 24, 2011 | 03:11 PM
rlporter's Avatar
rlporter
Default Error Code
Thvlv/sol malf circuit highe only code that is coming up is PO499 and according to my book it is EVAP emission vent. Any ideas.
Old Oct 12, 2011 | 04:28 PM
blazendizz's Avatar
blazendizz
bump ok any help would be awesome my car is doing the exact same thing 05 neon sxt runs and idles but when i hit the brake it sounds like a like air sucking and stalls and when i turn on the head lights same thing some times doesnt stall when the headlights turn on
Old Oct 12, 2011 | 04:43 PM
blazendizz's Avatar
blazendizz
you think maybe it could be a NVLD switch?
Old Oct 12, 2011 | 05:17 PM
darthroush's Avatar
darthroush
Section Moderator
P0499-NVLD CANISTER VENT VALVE SOLENOID CIRCUIT HIGH
POSSIBLE CAUSES:
NVLD SOLENOID
(K106) NVLD SOL CONTROL CIRCUIT SHORT TO BATTERY VOLTAGE
(K106) NVLD SOL CONTROL CIRCUIT OPEN
(Z1) GROUND CIRCUIT OPEN
PCM
NVLD is where to start the search it seems...
Old Oct 12, 2011 | 11:18 PM
blazendizz's Avatar
blazendizz
one problem to be honest i dont know what any of that is or were's its at
Old Oct 12, 2011 | 11:23 PM
blazendizz's Avatar
blazendizz
oh the nvld solenoid is the same as a purge solenoid? if so i just changed that but i got the part from a junk yard how can i tell if its still good
Old Oct 12, 2011 | 11:25 PM
darthroush's Avatar
darthroush
Section Moderator
It's near the RR wheel, right by the carbon canister.
Number 4 is the actual detector.
Old Oct 12, 2011 | 11:36 PM
blazendizz's Avatar
blazendizz
is number 1 the purge solenoid cuz i believe thats the one i changed today
