I made another post about timing and water pump issues. I am suspecting I have bent valves. I have never changed valves. So I am thinking if needed I will just pick up a head. I have a junkyard 5 miles away that has several 1st gens. There is another that is about 60 miles away that has 2 second gens.
My question is will a head off a 95-99 fit a 2000? Both are 2.0l SOHC.
I posted this same question on neons.org and I got the reply that they were the same. So I can get one at this place locally for scrap valve. Its a junkyard and they buy cars and set them off to the side. ITs not a traditional u pull it yard. I can probably get one for $10-15 so I will probably just buy one and see what happens.
But if anyone can shed some light on this please do so.
Also on car-part.com (searches local junkyards) it shows 96 and up will interchange with my 2000. Also shows that a 2.0l SOHC head from a Breeze will work also.
I successfully put a head from an '03 on a '95. I just changed the target magnet in the end of the cam. It worked great. Also had to drill and tap for EGR, no big deal.
