I think im really screwed now
Old Apr 3, 2011 | 10:51 PM
jasongkrantz's Avatar
jasongkrantz
Default I think im really screwed now
I WAS DRIVING HOME FROM WORK 'a 35 mile drive' and about 20 miles into it as i stopped at a three way my oil light and engine light blinked and then my car died i waited a few minutes about 10 and tryed to restart it it will not start it sounds normal just a really lagging sounding trying to start there is no leaking and no smoke any ideas guys
Old Apr 4, 2011 | 02:09 AM
darthroush's Avatar
darthroush
Section Moderator
A blinking check engine light indicates a major misfire. Start going over the ignition system.
Old Apr 4, 2011 | 11:02 PM
Moparkyle's Avatar
Moparkyle
The lights blinked once or continued to blink?
Old Apr 5, 2011 | 10:21 PM
jasongkrantz
ok so i got to the bottom of my problem my timing belt jumped time and ate my belt apart luckly this happened at a dead to almost stop and my valves didnt meet my pistons but 50 dollars and 3 hrs later its all running again and might i say better than ever no noise and alot more throttle response less vibrations thou i did have to go through the whole procedure twice because my tensioner ended up bieng to tight and i did this all in the rain under a tarp hel up with ladders and a flashlight to all who fear this fix it isnt really to hard just make sure youve got somebody to help you .
my lights all flashed because of my car dying i had a sending unit go bad a while back and thought this was an internal problem but seems i was way off my brother hit the nail on the head when he said so suttle YEP TIMING BELT a 1 min diagnosis lucky me i guess
Old Apr 6, 2011 | 01:33 AM
darthroush's Avatar
darthroush
Section Moderator
Did you replace the water pump and tensioner while you were in there? May as well have if the mileage is close enough to the service interval...
Old Apr 6, 2011 | 01:49 AM
jasongkrantz
i wish i could have... oil pump too but it was such an urgent fix that i couldnt wait until next week to get it all!! the tensioner and water pump are both in really good shape but im like you.ill also probably tackle that right center mount while im there next time . its really not that bad of a job and i liked doing if matter of fact. thanks for all the advice guys ive been spending alot of time latley on this thing and all help is appreciated
