Radio and Ac fan and Lights and Odometer blanks out
Old May 11, 2011 | 09:14 PM
houndog97's Avatar
houndog97
Default Radio and Ac fan and Lights and Odometer blanks out
The Radio and Ac fan and Lights and Odometer cut out for a second or two then come back on .But when I stop the car and restart it it goes away. Anyone else have this problem and know the fix?
Old May 11, 2011 | 10:23 PM
darthroush's Avatar
darthroush
Section Moderator
How's the battery?
Old May 12, 2011 | 07:14 PM
houndog97's Avatar
houndog97
The battery checks good and yeah the first time it happened i changed the battery and it went away for awhile but it's back now and battery checks good this time.
Old May 12, 2011 | 08:54 PM
darthroush's Avatar
darthroush
Section Moderator
Battery terminals and wire connections are in good, non-corroded shape?
Old May 13, 2011 | 09:33 AM
houndog97's Avatar
houndog97
Yes I cleaned them when I got the new battery........but what really gets me is why when I turn off the car and then start it again it goes away like something is reset. Maybe the alarm?
Old May 13, 2011 | 06:16 PM
darthroush's Avatar
darthroush
Section Moderator
OK. Terminals are clean; how about the wire connections to the terminals and PDC?
Old May 13, 2011 | 09:36 PM
houndog97's Avatar
houndog97
What is the PDC?
Old May 14, 2011 | 04:33 AM
darthroush's Avatar
darthroush
Section Moderator
Power Distribution Center. It's where the main relays and fuses are under the hood. I had some crazy stuff happening with my car, and one of those connections was corroded under the metal connections and was causing the problem.
Old May 14, 2011 | 10:42 AM
houndog97's Avatar
houndog97
I'll check it out thanks........and do you have to check under the connections in the box? Any pictures of where to look and how to do? Thanks again and I hope you fixed the rough idle situation you had going on. I did by backing the motor mount bolts from the wheel well just a bit it now idles smooth as silk.
Old May 14, 2011 | 03:20 PM
showsxt's Avatar
showsxt
I had than happen to my sxt last yr and it turned out to be the alternator you can have it checked out at autozone for free.
