Rattle Sound
Old Jun 14, 2011 | 12:49 AM
dodgeyneon's Avatar
dodgeyneon
Default Rattle Sound
I have a 2000 dodge neon that makes a rattle noise from the driver side whenever i go over uneven pavement. The sound goes away when I push the brakes. I have replaced the brakes and rotors and just had the control arm bushing on that side replaced. Anybody have any ideas what it could be?
Old Jun 14, 2011 | 02:43 AM
darthroush's Avatar
darthroush
Section Moderator
Sway bar bushings?
Old Jun 14, 2011 | 11:16 AM
dodgeyneon's Avatar
dodgeyneon
well i did look at those but they look fine. maybe there is something wrong with the caliper?
Old Jun 14, 2011 | 11:02 PM
Matix151's Avatar
Matix151
more info here? how long does the rattle last once it starts? does it go away when brakes are applied then come back when your off the brakes? maybe more of a clunk? maybe struts?
Old Jun 14, 2011 | 11:38 PM
dodgeyneon's Avatar
dodgeyneon
the sound comes back once i take my foot off the brake and the sound is definetley a rattling sound
Old Jun 15, 2011 | 12:04 AM
Matix151's Avatar
Matix151
could very well be the pads chattering . something is loose it seems , i would shake down the front end , check the wheels for lateral and axial play. so hard to diagnose over the web. just keep looking till you find something loose or worn out. sometimes it takes a while to pinpoint a noise , when u think u have checked everything , recheck again
Old Jun 16, 2011 | 10:17 PM
dodgeyneon's Avatar
dodgeyneon
I'm just about to give up I can't find anything other than the caliper is able to be moved just slightly. Is there a way that it can be tightened?
Old Jun 17, 2011 | 12:24 AM
Matix151's Avatar
Matix151
they move a tiny bit , its normal. you can try to tighten it , it has 2 attaching bolts , 10 or 12 mm .
Old Jun 17, 2011 | 04:20 PM
dodgeyneon's Avatar
dodgeyneon
i tightened the bolts and still getting that rattle. would the bolts need replaced? i mean i tightened them up and now there as tight as they will go. sorry for all this i'm kind of a car noob.
Old Jun 18, 2011 | 04:55 AM
darthroush's Avatar
darthroush
Section Moderator
Are you sure the sway bar bushings/possibly end links are actually good; not just "look" good?
