Help ME!
Old Jul 24, 2011 | 12:31 AM
NeonDan's Avatar
NeonDan
so thats what is causing my leaks?
even if i get it spotless and their is just scratch marks?its not going to do anything to save it?
couldnt u just get a new plate?
for the epoxy do u apply that on the whole silver surface and then put the solenoid back on?
Old Jul 24, 2011 | 12:37 AM
NeonDan's Avatar
NeonDan
why would the car be able to drive in drive mode though?
Old Jul 24, 2011 | 12:41 AM
Matix151's Avatar
Matix151
You never specified it moved in drive , is this a reverse soenoid u replaced?
Old Jul 24, 2011 | 01:00 AM
NeonDan's Avatar
NeonDan
i can start it up but when i put the car in drive nothing happens.
i bought this
http://shop.advanceautoparts.com/web...1710467673____
Old Jul 24, 2011 | 01:33 AM
Matix151's Avatar
Matix151
Ok so the trans works on pressure to operate those solenoids , if you have a large leak from that solenoid as u say then you are losing the pressure needed to operate the solenoid to shift the trans into gear. You need to remove all of the old gasket for the new one to seal properly. If u put a scratch or gouge in the sealing surface while cleaning it then the gasket will not seal anymore causing a leak and loss of adequete pressure. Remove it and check it over very good , make sure its seating flush all the way around. If its gouged then applying epoxy or marine tex to the new gasket will fill in the gouge or scratch. its a simple trick. Make sure the trans is full as well. Ur on ur own now , use common sense and simple theory , u can only do so much over the net to help someone. Good luck.
Old Jul 24, 2011 | 04:25 PM
darthroush's Avatar
darthroush
Section Moderator
That, and I've already gone over this with him in his other thread about this same thing...
Old Jul 24, 2011 | 05:37 PM
Matix151's Avatar
Matix151
ya i know i read that LOL , just time to face the facts
Old Jul 25, 2011 | 01:56 PM
hemi4spd's Avatar
hemi4spd
Im still trying to figure this out.
Why would you ask a leading question to give the impression the car moves, then to say it does not?
